Monty the Rwd R1 engined tarmac eating Minus
#556
Posted 26 April 2011 - 06:34 PM
#557
Posted 28 April 2011 - 05:32 PM
Next I wired the negative switch wire from the neutral switch and the positive to my reverse foot switch through a normal relay like this:
-trigger is netral light/switch
+input are both from fuse box
+output goes to reverse foot switch
It works and the floor mounted reverse button only works when the car is in neutral so I'm happy with that.
#558
Posted 30 April 2011 - 09:58 PM
#559
Posted 30 April 2011 - 10:01 PM
#560
Posted 03 May 2011 - 09:51 AM
#561
Posted 03 May 2011 - 07:59 PM
Finding decent multipin plugs is a pain though. I thought I'd got some good ones from cbs, but the pins slip out. I've poly sealed the wires into the plug to try and rescue it.
Edited by Alburglar, 05 May 2011 - 05:05 PM.
#562
Posted 05 May 2011 - 05:09 PM
Then fitted the arches
Handily the backs of the bolts were convenient for adding p-clips for the rear loom.
#563
Posted 06 May 2011 - 08:11 AM
Yeah, definately. Wiring was very time consuming, but feels great now it's done.
Those plugs are a PITA to use, really fiddly and no room for error, especially when you accidently put the wrong wire in the wrong hole.....but they are one fo the only waterproof plugs on the market at a reasonable price. You could go all military spec but then you're paying a lot of money.
The arches look good and will help with all kinds of debris, I guess rust wont be too much of an issue for you though.........
#564
Posted 09 May 2011 - 08:52 PM
I've wrapped my loom now everything is working.
Dash is in for the final time I think.
Offset brushed alumium styling...
...or I ballsed up and put my switches where they don't clear the dash bar.
Drivers View
Shift light and gear indicator are fixed on with sticky velcro tabs. Works well I think.
#565
Posted 09 May 2011 - 08:56 PM
#566
Posted 09 May 2011 - 08:59 PM
Its coming along well mate.
#567
Posted 10 May 2011 - 07:45 AM
I think I still have a slight oil leak from the oil sandwich plate. If I have I will have to whip it off again and remove another thread off the extension bolt, unless I can nip it up a little bit. Then I can do the final fit of the bulkhead, fit the seats, fix my wobbly head light and then it's MOT time.
err edit - ...and then it's MOT time...after I've finished fitting the scottoiler and refit the rear windows.
-then I'll fit an air scoop for the engine and make a zcars style bonnet channel to get the rad air out and help keep the front end down.
Edited by Alburglar, 10 May 2011 - 07:53 AM.
#568
Posted 16 May 2011 - 12:55 PM
As usual one step forward and two steps back.
AP racing do a brake master cylinder that fits a mini stud pattern in various bore sizes up to 1" wich is perfect and it's only £101, however it's 4 to 5 weeks for delivery!
Here is a useful link:
http://www.apracing.... Type_2386_2385
I think I'm gonna try a standard non servo dual line system first (yellow tag GMC227). It's a safer upgrade anyway and a bit cheaper. They are 0.7" and 0.75", so I figure it should work as good as my 0.75" did with with just the 4 pots at the front. The second 0.7 line can work the rears.
Got the boot on before L2B
Edited by Alburglar, 24 January 2014 - 09:34 PM.
#569
Posted 16 May 2011 - 09:38 PM
Success on the throttle return front. I spent a while experimenting with different fitting locations and springs and ended up with this.
The bolt on the bracket is necessary so the spring clears the choke slider.
#570
Posted 19 May 2011 - 09:21 PM
Edited by Alburglar, 19 May 2011 - 09:23 PM.
