Monty the Rwd R1 engined tarmac eating Minus
654 replies to this topic
#346 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 15 September 2006 - 07:45 PM
tried with my multimeter and it doesn't read anything???
So i need 170ohms in series then? or I take it 340ohms resistors in parrallel?
#347 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 15 September 2006 - 08:02 PM
yep thats it.
if the gauge needs to see 170 ohms then as long as when you measure the resistance across the 2 terminals then bobs your uncle
#348 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 15 September 2006 - 09:00 PM
You need 170 ohms accross the terminals, whether thats made up from other resistors (in parallel or series) or just one, it needs to be accross the terminals (as in parallel with the sender as it is a resistor).
#349 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 15 September 2006 - 09:59 PM
Als not working. well he is but he's exterminating his adopted pet worms.
Looking good there Al, hope its gonna be able to catch my lil 998 ;D
Maybe itll make it to german next year?? we can paint it red and put a yellow badge on it and draw a horse with huge balls on the badge!
or not!
#350 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 September 2006 - 02:55 AM
I think that would be bad luck.
#351 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 September 2006 - 03:47 AM
I understand now that I need to put the resistors in series but...
I'm also a bit confused in general about the theory behind this.
ED4ran has got a 260ohms (empty) sender and has used about 160 ohms of resistors to get it to the required 100ohms.
My sender (now turned upside down) is 240ohms (empty) wouldn't I need 140ohms resistors and not the 170ohms thats been suggested?
#352 miniboo
miniboo
  • 9,327 posts
Posted 16 September 2006 - 06:18 AM
yep i agree.
if you need 100 ohms and you have 240ohms then you will need 140 ohms worth of resistors.
#353 ed4ran
ed4ran
  • 2,849 posts
Posted 16 September 2006 - 10:45 AM
no because that would be adding were you want to reduce it by 140, you do this by putting it in parallel with the sender. You need 170 in parallel with the sender to reduce the resistance to the range required. HOWEVER, you can make that 170 Ohms up which ever way you like be it with resistors in series, parallel or just 1 resistor of that value.
The fact that we used approximatly 160 ohms to get a reduction of 160 is a coincidence.
#354 miniboo
miniboo
  • 9,327 posts
Posted 16 September 2006 - 11:16 AM
right i understand the 170 ohm thing now. so yeah they need to be put in parallel like Ed says
#355 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 September 2006 - 10:44 PM
I'm glad you understand bo because I don't understand how it's worked out at 170 at all, I'm pretty cluesless with componenets, but I do inderstand what I need to do now, make 170 either in one resistor or by putting numerous resistors, with a total value of 170 in series and then put that 170 across (parrallel to) the terminals.
Any one got a spare 170ohms resistor? because with the ones I've got (100, 40 and 3x10s) I'll end up with 5 in a row!!!
and that'll look poo.
-I'll give you 50p for it :-
#356 ed4ran
ed4ran
  • 2,849 posts
Posted 16 September 2006 - 11:41 PM
Use a 1k2 and a 200Ohm in parallel to get 171Ohms.
Maplin:-
200Ohm = 13p
1K2 = 13p
#357 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 17 September 2006 - 03:46 AM
cheers ed youre a star
#358 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 07 October 2006 - 02:29 PM
If you were wondering why I hadn't done anything lately it's because I was building the 1380 up ready for sale.
It looks good I think you'll agree.
duplex adjustble timing gear set up and water pump on
copper head gasket
the head was stripped and my friend stuck it in the cleaning tank at his work. It was painted with the same as the engine and re-built. I'm really proud of it it looks brand new!
Everything is torqued up and tappet clearances set
Most ancillaries added to finish
it's now for sale on ebay.
http://www.theminifo...showtopic=33495
#359 Pie
Pie
  • 7,695 posts
Posted 07 October 2006 - 03:41 PM
Thats one hell of a clean engine!
#360 dean_chad
dean_chad
  • 733 posts
Posted 28 October 2006 - 06:20 PM
alright Alburglar
any new updates? how you had it running yet mate?
dean
    Bing (1)
