Oops sorry this is your topic, and I'm high jacking, I did say top job, didnt I
Yeah, flattery allows you one O/T!
EDIT: I dunno about these sportpacks, they are all rubbed on the inside where the tyre has fouled em.
Freebie
Top Job by the way
Posted 17 February 2007 - 09:29 PM
Posted 17 February 2007 - 09:33 PM
Freebie![]()
Top Job by the way
Posted 18 February 2007 - 06:52 PM
Posted 18 February 2007 - 10:13 PM
Posted 18 February 2007 - 10:18 PM
Posted 18 February 2007 - 10:31 PM
Hmm, not sure about the Fester calipers. Hadn't really considered them to be honest, though I could run vented 7.9" disks on XR2 calipers I guess?
Man, don't make me change my mind again!
Edited by markrally73, 18 February 2007 - 10:44 PM.
Posted 19 February 2007 - 08:46 AM
No you cant, i tried fitting the vented type calipers but they have a bigger pad and outer diameter so they dont go under 10's unfortunately but i have used a later Mk2 1300cc caliper which just fits and has a better slider system and pad retaining clips, Pads and discs for £20 new, You cant go wrong for that??
Let me know if you want anymore info?
( You could do the lot new including hoses for £150)
Save you dosh and sack the 4-pots, there just more Blinging Eye candy which you cant see, they wont really do much more stopping as the pad is tiny, Im even taking my Kad's off as they aint much Kop in my application, need bigger anchors, may keep em for the next project.
cheers
Posted 20 February 2007 - 06:17 PM
Posted 20 February 2007 - 06:40 PM
Posted 20 February 2007 - 06:49 PM
After thinking about it, I have ordered one of these today:
<----- Press the ikkle face!
It's better than machining me brand new bottom pulley I reckon. Plus it'll give me more accurate adjustment of me timing disk. Mo' money!
Posted 20 February 2007 - 09:16 PM
Top quality
You do realise that you will need the minispares special bolt and a 1/2" hex socket bit to torque it up(which incidently Minispares dont sell, wich is a bit daft considering that its an oddball tool these days). Give Buck and Hickman a ring, they will sort you out for that
Posted 22 February 2007 - 08:44 AM
Posted 22 February 2007 - 10:19 AM
weigh the remainder of the shell in as scrap metal :'(
Posted 22 February 2007 - 10:22 AM
