The Freak (with Added Xe)
#1321
Posted 22 August 2010 - 05:48 PM
#1322
Posted 22 August 2010 - 06:49 PM
#1323
Posted 22 August 2010 - 07:34 PM
#1324
Posted 22 August 2010 - 07:36 PM
#1325
Posted 25 August 2010 - 12:20 PM
Refit it and check the gap
#1326
Posted 25 August 2010 - 06:48 PM
Getting close now......
#1327
Posted 25 August 2010 - 08:32 PM
I just keep coming back to this custom inlet. Every time I reseal it, or generally have a play with it, the engine's behaviour seems to alter.
I'm still trying, but it's just not getting me anywhere. I'm pretty hacked off, as when I bought the Allspeed kit, I was told that the standard inlet would fit, but it simply doesn't. There's not enough room for it at all.
I am going to have to go straight to phase 2 I think, which is ITBs and Emerald ECU (or similar). Simple fact is, I don't have time or finances to do that before the run. If I can make it drivable, I will use it!
#1328
Posted 25 August 2010 - 09:31 PM
Can you actually see anything wrong with the inlet aswell?
#1329
Posted 26 August 2010 - 04:38 PM
#1330
Posted 26 August 2010 - 05:09 PM
Kam, the inlet off the standard Corsa won't fit, so most people fit ITBs and mappable ignition. Instead, I wanted to go down the "powerbox" route, which is something that a lot of Corsa owners do to de-restrict Vauxhall's VERY restrictive inlet. The problem is; the normal off-the-shelf powerboxes have the TB mounted on the O/S, which is no goodfor my application.
It's annoying, because ITBs were always the plan. But I wanted to get it up and running and run in with the standard kit. No joy with that route though, so I'll have to go to the Gixxer ITBs that I have in the garage. Poop poop, that's another £500+ by the time I've sorted out management for the setup, so ATM it's a no go.
#1331
Posted 26 August 2010 - 08:00 PM
#1332
Posted 27 August 2010 - 10:23 AM
#1333
Posted 27 August 2010 - 07:40 PM
#1334
Posted 31 August 2010 - 10:17 PM
I'm just resigned to the fact that I'm not up to this kind of work on cars. I'm gutted to not have it here as I sit in the Travelodge the night before BH2N. Epic fail!
When I get back home, that's it. Gixxer TBs, Emerald ECU and some serious effort. It will be on a track this year, just not the mighty Nürburgring.
#1335
Posted 31 August 2010 - 10:23 PM
