The Freak (with Added Xe)
#1291
Posted 10 August 2010 - 09:03 PM
#1292
Posted 10 August 2010 - 09:12 PM
#1293
Posted 14 August 2010 - 05:52 PM
So, the one thing I never expected it to be (seeing as I hunted around on various fora for a "perfect working condition" meter) seems to be the cause of the rough running.
I've seen cars with knackered air flow meters before, yeah, they idle roughly, yeah, it effects the running, but I didn't think it'd cause it to run as roughly as it has been. I hope it is that. I'll chance another second hand one, see what that does. A new one is about £150, but I can't afford that at the moment. Poops!
#1294
Posted 14 August 2010 - 08:41 PM
#1295
Posted 15 August 2010 - 06:32 AM
If you could see if you've got one, then send a piccy, that'd be great.
#1296
Posted 16 August 2010 - 07:20 PM
Bit it still ain't right. It's misfiring as soon as it gets warm. Like the ignition system is going to pot after a few minutes of running.
I've tried:
New TPS, helped a little
New MAF, helped a lot
New coilpack, the old one was cracked so I changed it anyway
New ECU, no real difference at all.
When it's playing up, turning it off then restarting seems to clear it.
Could it be the crank sensor on the way out anorl??? Man, it's frying my noggin now!
#1297
Posted 16 August 2010 - 07:31 PM
#1298
Posted 17 August 2010 - 08:18 AM
It's also had a new solenoid in the ICV!
#1299
Posted 17 August 2010 - 08:57 AM
#1300
Posted 18 August 2010 - 06:41 AM
Runs much better now.
The fuel pressure is right. I've got a slight air leak on the inlet. The throttle stop needs a little adjustment. But yeah, loads better. The management light stays on still though. Maybe just needs clearing/resetting?
#1301
Posted 18 August 2010 - 10:17 AM
#1302
Posted 18 August 2010 - 03:01 PM
Also, I think I'm over-throwing the clutch slightly too, so need to slacken the cable off a little, or put an adjustable stop on the floor.
Problems, problems, no time to sort. Nightmare.
#1303
Posted 18 August 2010 - 05:06 PM
As for your overthrowing clutch check out my one near the bottom of page 12, simple idea from a guy over on 16v
You got plenty of time to sort your car out, well 13 days
#1304
Posted 20 August 2010 - 08:30 PM
I've changed every flaming sensor on this engine and it's still not running right.
Symptoms: starts and idles well from cold. When it starts to get warm, it won't idle, runs rough and won't rev freely from low revs. I am sure it's over fuelling.
I've tried:
New ECU
New TPS
New coilpack
New ICV
New MAF
New lambda sensor
Sealed inlet of any air leaks
Car gets a little better each time, but still not right. Once you've got "through" the first 5 minutes of driving, it's much better, but still seems to over fuel.
I can't drive it to Germany like this. I'm scared I'm going to get bore-washing whilst it's running in. I've also tested all electrical connections to the ECU. The management light stays on, but it won't flash out any fault codes.
What do I do? Just drive it more and hope it doesn't do any damage? I've only done about 150 miles of driving so far, but need the engine run in by next weekend, ready for Germany. I'm feeling like I can't do right for doing wrong ATM.
One other thing, I've not had a fuel tank vent valve plugged in, so I'm going to find one tomorrow and plug it in. I tried the one off my Vectra, but it made no difference. I'm stuffed!!!
Tomorrow's plan: got to scrappy, source FTTV, spare coolant temp sensor, fit to mini and just drive about 100 miles with spares and tools in the car.
#1305
Posted 20 August 2010 - 08:34 PM
Man alive, I'm panicking here now. Sheesus!
