The Freak (with Added Xe)
#1246
Posted 01 August 2010 - 10:58 AM
Yeah, I hope it turns up in time, but it's not the end of the world if it doesn't.
It will be ace to take it out for a proper lengthy run once it's passed though. That's when I'll start finding the little niggles
#1247
Posted 01 August 2010 - 04:05 PM
No no, I'll start finding them now
Won't idle when it's hot now.
Won't rev freely either. I'm not sure whether it's a management thing or the "design" of my inlet manifold...
More testing and fault fixing to follow.
I still love it though!
#1248
Posted 01 August 2010 - 04:08 PM
#1249
Posted 01 August 2010 - 05:01 PM
IAT sensor is a new un, wire continuity checks out OK, plug and pins look good. I'm thinking of swapping out the TPS for good measure anyway.
#1250
Posted 01 August 2010 - 05:12 PM
#1251
Posted 01 August 2010 - 05:32 PM
New Vx one tomorrow.
That's about the only sensor I haven't already swapped for either good second hand or new. Wheeeee!
#1252
Posted 01 August 2010 - 08:18 PM
Aye, throttle pot. Is buggered
Good going Mr Detective
How much powerrrrrrr is this opel
#1253
Posted 01 August 2010 - 09:06 PM
With the standard engine, cams and head, but an SBD taper throttle body setup, you can achieve 160-165 bhp straight away!
With a skim, head work and cams, plus ITBs, 200bhp is possible.
That's why I'm looking at adding the Gixxer ITBs and a lightweight flywheel, another head and mappable ECU. I'd love to see over 150 out of this engine when phase 2 happens!
#1254
Posted 01 August 2010 - 09:34 PM
Drivers skill then!
#1255
Posted 01 August 2010 - 09:43 PM
#1256
Posted 06 August 2010 - 05:40 AM
I'm seriously nervous now. Nothing back from the DVLA, so it's going through the MOT with a 1275 engine on the documents, gutted about that, but never mind, it'll be sorted out soon.
I fitted a new TPS last night, tested the old one versus the new one. Old one was definitely not working right, but there's not really that much change. I've checked the wires from the TPS to the ECU and they all check out, all ECU and sensor earths are good. Engine earths are good, it's just got another problem somewhere running alongside the original one. To say it hasn't changed much isn't really accurate actually. It's more responsive to throttle movements now.
It's still idling roughly, worse when it's warm. It'll get to the stage where it'll just cut out when it's warm. I'm thinking it's the MAF too now, which I'm pretty peeved about as I bought a "good" second hand one. The engine didn't have one with it when I got it, so I bought one off Migweb. I'm pretty sure that on the C16XE the IAT sensor is part of the MAF unit? Anybody know? I know there's only one spare plug (a red two-pin one) on the loom, but I aint got a clue where that's supposed to go and can't tell from the Haynes wiring diagram. Unless that's supposed to be connected to an IAT sensor somewhere?
I can either try and find another today, or just take it to its MOT as it is.
I'm setting off well early though tomorrow and going the long way around.
#1257
Posted 06 August 2010 - 06:31 AM
Vauxhall World parts list an Inlet Air Temperature sensor for the C16XE, so I guess I'd better get one ASAP. I hope the local Vx man has one in stock! It'll have to go into the base of the air filter. Poop poop!
Engine conversions are too much for me!
#1258
Posted 06 August 2010 - 07:46 PM
Did you get one Matt? And hows it now?
If you didn't then I wouldn't go the long way round.......engine might get a bit too warm
Oh and Happy birthday.........for tomorrow
#1259
Posted 06 August 2010 - 08:04 PM
But, I'm still taking it tomorrow. Even with it running rough. It'll have to be tested tomorrow, or I simply won't have time. Poops!
#1260
Posted 07 August 2010 - 08:25 AM
Fingers crossed now!
by the way, Jesus H Christ! It's certainly nippy!
