The Freak (with Added Xe)
#1006
Posted 01 July 2009 - 12:33 PM
tip for steam seals... 10mm long socket.
#1007
Posted 01 July 2009 - 01:07 PM
The decent Mahle pistons are only £50 a piece, then there's the ARP bolt set, then there's the...................Oh, I dunno. Just seems that it might as well be the way I want it, now it's all apart and being rebuilt.
Ah well, if it's worth doing at all, it's worth doing properly! isn't it?!?
#1008
Posted 01 July 2009 - 01:16 PM
#1009
Posted 01 July 2009 - 01:19 PM
I've already thought about it!
#1010
Posted 01 July 2009 - 01:21 PM
#1011
Posted 01 July 2009 - 01:31 PM
Anyway, shurrup. It can't happen unless I sell a limb!
#1012
Posted 01 July 2009 - 02:02 PM
Do it! DO IT!!!
I'll make you a prosthesis!
#1013
Posted 01 July 2009 - 08:45 PM
I thought the idea with these Vauxhall lumps is that you throw it in, thrash the living poo out of it and when it breaks, you buy a written off Corsa/Astra/Vectra, alleviate it of it's engine, weigh in the rest and put the 'new' engine in the Mini - just like we used to do with Metros 10 years ago (except the Metros were normally rotten rather than crashed)!
JR
#1014
Posted 01 July 2009 - 10:39 PM
the appeal i have to these blocks, is there real engines unlike A series =p 5 bearing cranks, 5 gears, reliable! sorted!
#1015
Posted 01 July 2009 - 11:31 PM
Gonna be well worth all the effort your putting into it. Can I ask approx how much £££'s this little project has cost so far ?
#1016
Posted 02 July 2009 - 06:28 AM
Cost so far is ridiculous, I've changed my mind that many times, then given parts away that the total's running to many thousands.
If I'd decided to go down this Vauxhall engine conversion route from day 1 and had taken the mini, bought an engine, bought the subframe kit, done a decent job of all the extras like the pedal box, fuel lines, it'd be about £2k ish.
Not bad when you think about how much you can spend on trying to do a decent A series build. If I look at what I spent on the 1380 that I built, with the SCCR gear kit and all the luvvly jubbly A series bits, the costs were far far above that £2k.
I'd agree with Alex 100%, that these engines are so much better than your average A series. But to be fair to the A series, they're an old design, they're made to be a compact unit and that's what gives them their inherent weeknesses (not enough main bearings being a good example!
I'm in a pretty good position to do a cost comparison of doing a high spec A-series, or a decent Vauxhall conversion and I'd recommend that the conversion route is by far the more sensible option.
#1017
Posted 25 July 2009 - 07:13 PM
Got the gearshift bulkhead box welded in place (hope it's in the right place)
Also trial fitted the gearbox to see how it lines up (looks OK).
Should have my freshly rebuilt engine back in a week too, so I reckon I can really get cracking next weekend! I've also bought an Acewell digital dash, so got to wire that in (along with the ECU and all the other gubbins).
WHEEEEEEEEE!
I have to accept that when I go the ring, it's going to look a dog as I aint got time nor money to do the bodywork. That'll get done when I get back.
Desperately need to get my hands on an MPi rad and fuel tank now though, like tomorrow! Plus I need a pair of tower bolts!
#1018
Posted 26 July 2009 - 10:15 AM
WHEEEEEEEEE!
So we're going then? Are you suuuuuuuuuuuuuure she's gonna be road worthy on time???
I've got al my bits crossed.
#1019
Posted 26 July 2009 - 12:28 PM
So excited!
Now get cracking and get her ready in time, no excuses.
#1020
Posted 26 July 2009 - 04:16 PM
Keep it coming Matt
