The Freak (with Added Xe)
#931
Posted 08 February 2009 - 05:16 PM
#932
Posted 08 February 2009 - 08:26 PM
#933
Posted 08 February 2009 - 08:32 PM
Edited by RacingGreen, 08 February 2009 - 08:33 PM.
#934
Posted 08 February 2009 - 08:35 PM
I'm only using hoses on mine (well, car rubbers) to hold it in place. The manifold runners will have a little lip in them for the carbs to sit neatly inside.
#935
Posted 08 February 2009 - 09:04 PM
#936
Posted 08 February 2009 - 09:23 PM
But, I still need to get a gear change unit (lever and rods), mod them so they fit nicely and then set them all up. I'm hoping to get away with a small hole in the bulkhead, rather than the usual big box that people cut out. We'll see though, I believe I can do it if I shorten/modify the linkage on the 'box, so I'm going to do some fettling with that today too.
Matt,
Take a look at this thread on 16vminiclub for details of linkage mods. It looks like this is being done on a big-block but the gearchange mechanism looks to be near enough identical to the small-block ones.
Hope it helps,
JR
#937
Posted 09 February 2009 - 07:57 AM
#938
Posted 09 February 2009 - 06:50 PM
#939
Posted 09 February 2009 - 07:38 PM
Cheers for that Al. Will have a fettle once the engine's in I think. I read on 16v that some geezer had managed without fitting the box in, so I was going to try and avoid it if I could.
#940
Posted 17 February 2009 - 09:29 PM
What subframe are you using now that you are sticking with doing the C16XE conversion?
#941
Posted 18 February 2009 - 07:56 AM
Whats your estimated time of completing the project Matt?
Well, I'm hoping to get if finished over the Christmas break!
Nah, as long as it's done and all 'settled in' before ring time, I'll be more than happy. Realistically, the majority of the real purchasing has been done now. So it's jsut a case of banging it all together!
Should be ready by Easter I'd hope, but we'll see. My timeline is a very organic thing, it keeps growing all the time!
The Matt What subframe are you using now that you are sticking with doing the C16XE conversion?
Bodgerised by the big man himself!
#942
Posted 21 February 2009 - 08:39 PM
I've bought more parts!
I now have a GRP front end (removable bonnet type),
Corsa gear lever and linkage,
A BIG sheet of 5083 aluminium to make a fuel tank, a dash and general brackets and stuff from,
A head bolt set for the engine rebuild,
And, some general toolage for the garage!
I've spent a bit of time on her again today, but intend to have a good day in the garage tomorrow. Hoping to get the frame completed tomorrow, but we'll see.
And then it's bodywork sorting time
#943
Posted 27 February 2009 - 08:14 PM
#944
Posted 27 February 2009 - 08:15 PM
I'll get some tomorrow.
I've been waaaaaaaaaaaaay too busy with BH2N Retro stuff to do any mini work though.
#945
Posted 01 March 2009 - 06:26 PM
Fair play to you sirPictures!
