Weoooooooooeoeoeee!!
Not sure what that means, or how to pronounce it, but my shafts are here!
So, I can centralise the engine/box in the frame and crack on with welding it up! WOOO!
Aaaand, I have sorted out someone to tig my manifold up for me, that got started yesterday (by me)
The carbs are closer to lining up with the inlet ports on the smaller block engine, so the runners don't need to be on that much of an angle. I just need to cut the four runners so they line up with the carbs, then chop four little 35mm long bits of tube, machine them so they've got a nice seat on them for the carb, then get someone else to weld it all together. Plus, the angle of the float chambers needs to be flatter, at the moment they're a few degrees off horizontal (well, vertical in the second picture), but that'll be sorted by my Mr Mig man!
Something that I've noticed though, the inlet ports are MASSIVE on the C16XE head, they're bigger than the C18XE ones by far. So, the 50mm OD tubing is actually a little bit small. Might ask Migman if he can slit them and weld a wedge in there so they taper out from the 45mm OD on the carb to about 60mm OD on the flange. Mmmm, flange *dribbles*
So, all I really did was saw up some alloy tubing, which will probably be replaced with different alloy tubing that's been cut by a professional!
I'm just using a manifold gasket for alignment for now, but I've found a guy that's going to cut me a flange from 10mm thick aluminium. Should go together nicely really.
