The Freak (with Added Xe)
#901
Posted 25 January 2009 - 08:07 AM
#902
Posted 26 January 2009 - 02:19 PM
So, now I've made a choice about the FReaK again! Yes, I've changed my mind!
Anybody want to buy a C18XE engine and an F18 gearbox?
I'm now going to be using a C16XE (small block) engine and an F15W or F13W gearbox. My main aim is to have the car look standard from the outside, and for it to look a little tatty. Having a standard length roundnose front isn't going to be too easy with a large block, but it will be with the smaller block option.
I'm going to carry on with the frame I've started, but buy a pair of shafts from Allspeed engineering. I need them to centre the engine and box in the frame (unless someone's got some I can measure up, or can give me a dimension for the location of the engine/box in an Allspeed small block frame???).
So, the new spec:
rebuilt C16XE engine, running a lightweight billet flywheel and a pair of Kent 'supersport' cams
R1 carbs for now (as I've got them) on a custom alloy manifold
Megajolt ignition
4 branch exhaust manifold,
10" rims
Acewell digital dashboard
Steel flip/removable front
custom alloy rad.
The standard engines (injection, with cat) put out 109bhp I think. On the standard engine, the cams are worth a few extra donkeys, the R1 carbs might balance that out. So anything around 120bhp should be possible I think.
to be honest though, a mini with a 5-speed gearbox, reasonable MPG and around 120bhp will be a dream come true.
I just think it's a far better option than a compromised big block build. Hopefully, I'll get some money back on the C18XE and all the parts. I only paid a small amount for it, and it came with everything (manifolds, ECU, loom, radiator, fan, driveshafts etc.).
As for the C16XE, it cost me £28 for the lot! It looks like it's in good nick externally, but I'll be doing a strip down over the net week or two and getting the bottom end sorted.
#903
Posted 26 January 2009 - 03:54 PM
Sounds like a good plan though, with the hint of street sleeper in there aswell. And I was under the impression(most probably wrong though) that the c16 and c18 block were interchangable. I may have just made that up though.
Also following the pattern I bet you've considered the 1.4 aswell
#904
Posted 26 January 2009 - 04:18 PM
It's odd to hear that the 1.6 puts out 109bhp as standard, I was expecting lower. Once again your project sucks me in!
Just wish I could get to the garage to work on mine
#905
Posted 26 January 2009 - 06:55 PM
Assuming you don't change your mind of course!
Cheers - John
#906
Posted 26 January 2009 - 07:43 PM
One should NEVER assume that!
I've been looking at SBD stuff too. Could make a right tasty little motor out of this if I had the moolar!
Anyway, I have a mate that worked at Jenvey!
As for the output, pah, I'd be happy with 100bhp to be honest.
#907
Posted 26 January 2009 - 08:48 PM
Not that i've been working on it since then you understand. Started it in March last year and really want it up n running this summer. Yeah right!
I looked at SBD stuff myself but 2K is a bit steep for me. Got the Megasquirt and throttle bodies for £1100 from m-tech. Just waiting on delivery of throttle bodies to trial fir them to see if i need to move master cylinders inside
John
#908
Posted 27 January 2009 - 10:57 AM
Anyway, I have a mate that worked at Jenvey!good products!
What bhp was your old 1380 putting out Matt? when are you hoping to have the XE conversion finished by?
#909
Posted 27 January 2009 - 01:11 PM
Never had it dynod or RR'd. I'd guess near to the ton mark though. It was certainly pretty quick off the mark!
Hoping to get the conversion finished by March/April ideally.
#910
Posted 30 January 2009 - 08:51 PM
WEEEEEEEEEEEEE! WOP WOP!
#911
Posted 31 January 2009 - 11:10 AM
where did you get an xe for £28?
#912
Posted 31 January 2009 - 11:34 AM
I bought it off ebay, but it's having a strip down and rebuild before it gets used in the car. At least now that I have it, I can finish off making the frame and mounts for it, the engine rebuild won't take long at all, but it'll depend on whether I decide to upgrade the bottom end at all.
#913
Posted 31 January 2009 - 04:11 PM
nicely, rob is a nice guy, shame he doesnt sell a kit to replicate what he has in his mini, 270bhp red top front engine RWD, lol.
Are there any pictures of this? And what are the performance figures like?
#914
Posted 31 January 2009 - 05:07 PM
#915
Posted 31 January 2009 - 05:21 PM
