The Freak (with Added Xe)
#856
Posted 08 November 2008 - 04:38 PM
I've played with the dimensions of the Corsa one that you posted up and I reckon that's going to be a tight fit, but just about achievable.
#857
Posted 09 November 2008 - 05:01 PM
I thought you said it'd take you ages, looks to be going really well!
#858
Posted 10 November 2008 - 05:22 PM
I need to get my hands on your flange (heheheheh)
Where did you get that from, I have to make myself an exhaust manifold too. tHanks
#859
Posted 10 November 2008 - 06:05 PM
to be honest the best way to do it is to get a drawing off to a LASER cutter and ask them to do it as a one-off for you.
#860
Posted 10 November 2008 - 08:58 PM
Now both side braces are made and ready to be welded into place
Still not too confident with this kind of work, but it seems to be coming together OK.
In the photos the O/S brace is too far outset, it needs to be about 10-15mm further in, but it's only resting there at the moment. I've also got to weld some caps onto the radii on the braces too. I'm thinking I may draw up some proper plans when I've finished it, so anyone can have a go.
I've made the box section pretty well overspec really. It's 40x40x3, which is overkill. But, I've also made the frame big enough to take phase 2 of the engine plans!
#861
Posted 10 November 2008 - 10:47 PM
Oh do tell more!
#862
Posted 12 November 2008 - 01:20 AM
Keep up the good work sir
#863
Posted 13 November 2008 - 01:22 PM
Sooo, parts (bends) are ordered for the custom manifolds, they should be here tomorrow. Frame should be finished by the end of the weekend too. So, next week I'll make up the manifolds, get them as tight to the engine as possible and I can then work out (with the engine temporarily mounted in the frame) how much room I'm going to be left with.
I'm undecided whether to go steel front, GRP front or CF. to be honest I'm thinking that CF or GRP will be easier to modify than a steel one. I just feel that a steel one will be more of a proper job. I'm planning to have the front mounted on my frame, so it tilts forwards (as most do), but so that there are no external releases (like rubber hooks, bonnet pins etc). The intention is to have an internal release mechanism on the inside of each A-panel, but it'll depend on how wobbly that ends up being! I kinda like the idea of the front being a one-piece job too, but that'll depend on whether I go for steel or composite.
#864
Posted 13 November 2008 - 01:30 PM
Do it properly.
#865
Posted 13 November 2008 - 01:59 PM
And would think you would have the same problem with a GRP one without a bonnet, the only problem then is if you have a full flip front with a bonnet, once flipped you can’t direct get access to the front of the engine without having to go to all the hassle of removing it first.
#866
Posted 13 November 2008 - 06:41 PM
Karl, yeah I am thinking of making it so that the hinges are actually quick release on the inside, just a pair of pip-pins on the hinge mount (or even instead of hinge pins).
#867
Posted 13 November 2008 - 08:14 PM
And I’ve got the front end held down with the 2 bolts through the standard front teardrop stubby mounts and at the back for the a panels 4 Allen head m.8 bolts, I had thought about a hidden locking system for the a panels, but couldn’t work out a way that didn't look messy.
#868
Posted 15 November 2008 - 07:46 PM
Aaaand, I've now got a 6 point roll cage for her!
Going to do some more fabricating tomorrow and might do a dry fit of the roll cage too.
#869
Posted 15 November 2008 - 08:32 PM
#870
Posted 16 November 2008 - 04:19 PM
Haven't really got any pics of the roll cage to be honest, I'll get some tomorrow though. CBA to work on it today, been working on the Rocco instead for a change.I demand pics! Also hows the subframe coming along? Im doing a Swift conversion and I should be finishing mine soon enough. I get the feeling this is going to be an awesome build.
Going to have to put some more effort in on weeknights this week methinks, plus I need to buy steel front end panels.
