The Freak (with Added Xe)
1446 replies to this topic
#751 Juju
Juju
  • 3,620 posts
Posted 18 February 2008 - 08:38 AM
:wub:
Fwwwooooooooooooarrr!!
*rubs thighs & smacks lips*
Glad you got her purring, Matt. Are you in love again now, then? :(
#752 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 18 February 2008 - 08:55 AM
Not quite sure about being in love with her again yet. She's still a little minx!!! :wub:
#753 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 18 February 2008 - 09:37 PM
Another night in the garage has revealed that my brand new (well, done about 50 miles) EDIS coil is faulty! :)
Bladdy Ford parts! >_<
#754 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 18 February 2008 - 09:45 PM
cccccooooooooorrrrrrrrrrrrrrrrrrr >_< :P :P
#755 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 18 February 2008 - 10:33 PM
I know :)
Gonna paint the bonnet soon and get some door circles or rectangles on there. >_<
#756 Jammy
Jammy
  • 25,397 posts
Posted 18 February 2008 - 10:51 PM
How did you work out your coil was faulty? And what symptoms was it causing?
#757 minituga
minituga
  • 220 posts
  • Local Club: Forumini
Posted 19 February 2008 - 02:16 AM
Congratulations!
I've learned a lot from your post!!
I love your engine bay, as its the best looking, i've seen here!!
#758 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 19 February 2008 - 02:30 AM
Fix Or Repair Daily
#759 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 February 2008 - 07:37 AM
I've got some misfires throughout the rev range. At first I thought it was down to bad setup, so I connected my timing strobe to cylinder number 1 and started to rev the bugger manually. When revving it I saw that I was losing signal to my strobe and that the engine was struggling (it was only firing on three or even two cylinders). I played around with the multiplug that powers the coil and it was a little loose, the revs dropped, then I wiggled it a little more and there was a MASSIVE backfire and the revs picked back up.
Sooo, I think that what's happened is that there's been a loose contact on the coil, this has maybe been causing some of the misfires that I've had, but it's also damaged the coil. I was losing a spark on cylinders 1 and 3 (which are on two different coils on the EDIS pack) from about 2krpm and above. When I switched the HT leads around the lost spark followed the same coil outlets (ruling out lead problems). It's a PITA, but I think it may have been caused by having a loose multiplug in the end. It's a brand new coil too! :)
@Minituga, thanks for the compliments :lol:
#760 minituga
minituga
  • 220 posts
Posted 19 February 2008 - 02:08 PM
what kind of spark plugs are you using?
#761 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 February 2008 - 04:55 PM
ATM I'm using BP6ES plugs with gaps set to 0.9mm, they should be fine for the 'jolt setup I think :lol:
#762 minituga
minituga
  • 220 posts
Posted 20 February 2008 - 11:26 AM
BP6ES?
what brand is that?
#763 Jammy
Jammy
  • 25,397 posts
Posted 20 February 2008 - 03:26 PM
NGK.
#764 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 20 February 2008 - 03:43 PM
Fix Or Repair Daily
Found On Rubish Dumps :o
Looking good maffyew. Is it gonna make an appearance at malvern? :)
#765 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 04 March 2008 - 01:53 PM
Dunno yet Pie. Not sure if I CBA to go there really.
But, she's been used every day to get me to work and back for the last week or so with no problems, aaaand she's returning around 20mpg, which is nice.
She also lights the likkle tyres up if I let her! >_<
