The Freak (with Added Xe)
1446 replies to this topic
#331 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 24 April 2007 - 07:02 AM
Also, good stuff, a man who gets his hands dirty. Now stop falling over in the dirt and get it running :)
Two core rad all the way :w00t:
Going back in the garage tonight to finish off the bottom half of the engine (sort out the timing cover, VR pickup mount etc.).
Just about to order a two core with a set of decent hoses from Minispares (woohoo for discounts) and I need some decent fuel hose too (Goodridge 200 series). Only other thing I need to sort out now (buying wise) is a fuel pump inertia switch. Weird thing is that I thought I had one somewhere off an Escort!! :P
Cheers for all the comments guys!
Oh yeah 'flange' is one of my favourites too Dog! :kiss:
#332 vtec matt
vtec matt
  • 23 posts
  • Local Club: 3 Counties Mini Club
Posted 24 April 2007 - 05:42 PM
Looking good.
Have you looked into the alloy rads ?
#333 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 25 April 2007 - 06:31 AM
Looking good.
Cheers,
Yeah, I did contemplate an alloy one, but I thought it would be a bit too expensive to be honest. I am just gonna try this 2 core one from Minispares. From what everyone else has said, it will be more than capable of cooling the FReaK.
#334 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 25 April 2007 - 09:29 AM
Matt - I'll soon tell you at the weekend - I'm completely overhalling my cooling system, new pump etc, etc etc... most of all a 2 core rad from Minispares - if its solves my overheating problem, then you'll be fine :lol:
#335 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 25 April 2007 - 09:31 AM
Matt - I'll soon tell you at the weekend - I'm completely overhalling my cooling system, new pump etc, etc etc... most of all a 2 core rad from Minispares - if its solves my overheating problem, then you'll be fine :ermm:
Coolies :lol:
#336 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 25 April 2007 - 08:28 PM
No worries on 100bhp with the 2 core, no sign of over heating, I know people wih 140bhp that run one :lol:
#337 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 25 April 2007 - 08:31 PM
well to let you know Matt...
I've fitted a new waterpump, new fan, new 2 core tad, 15lb rad cap, and I can now say, the overheating is SORTED :lol: :ermm: :)
#338 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 26 April 2007 - 05:12 PM
I've fitted a new waterpump, new fan, new 2 core tad, 15lb rad cap, and I can now say, the overheating is SORTED >_< :lol: :-
Cool :lol:
Well, mine should be waiting for me at work tomorrow! :xxx: Along with some other spangly bits to go in there.
Gonna have a day at it on Saturday, I want to get the brakes and suspension fitted really amongst other things! :gimme:
#339 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 27 April 2007 - 04:37 AM
Oooh want piccys of all these sparkly bits that are gonna go on, matt!! >_<
#340 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 27 April 2007 - 07:20 AM
Oooh want piccys of all these sparkly bits that are gonna go on, matt!! :lol:
>_< Okies! :-
#341 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 27 April 2007 - 12:18 PM
Hmm, Some of the shiney bits aint turned up yet! >_<
But here's my most recent order from Minispares.
Supercool 2 core rad and a set of silly hoses! :lol:
Also got a thermostat blanking sleeve and also some spare brake pad retaining pins and retaining plates for the 4 pots.
Nicked some stainless steel hose clips from the workshop too! :-
#342 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 29 April 2007 - 01:34 PM
Okies, well, that lot above is now on! The radiator cowl bottom bracket is scarily close to the trigger wheel though. I have had to adapt it to make it easier to get the rad in and out. With the SC pickup kit for the Megajolt, I have to remove the bottom radiator bracket to get the fan belt on and off!
When I flip-front the car I am gonna make a new radiator bottom mount which will make the rad sit about 10mm further away from the engine, I'll then have to modify the cowl to make up for the gap! Bloomin minis! :errr:
#343 Sprocket
Sprocket
  • 7,266 posts
Posted 29 April 2007 - 07:53 PM
Ha Ha, sorry dude, i should have mentioned that, i had the same problem, but when i had the rad out I massaged the mounting bracket on the cowl for more clearance
It does fit with little room to spare
another thing you may want to consider doing as i had to do, is grind back the first couple of threads on the Minispares special bolt. This prevents it bottoming in the crank threads, which would other wise result in clamping force being reduced if any atall wich is what i found. Also use some thread locker on the threads or it WILL come loose, with out fail it will come loose. :errr:
#344 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 30 April 2007 - 06:59 AM
Yeah, I basically opened out the holes through the lower rad mount where it bolts to the engine mount (opened them to 7/16") then fitted the two bolts with a more substantial washer, just to give me some more adjustment. The two bolt holes that face toward the pulley (radiator cowl-radiator bracket) are now slotted, so the rad can be dropped in from the top with the bolts already in place, meaning it only takes a couple of spanner turns to tighten them up. I will threadlock the bottom pulley bolt, but I need to get a proper tool for it, it's a 1/2" Allen bit, but I 'modified' a 14mm sump plug one to fit (angle grinder). Note to self, bottom pulley bolt needs removing and tightening/threadlocking!!! The other thing with the SC kit is that the pickup mount bracket only has a tiny amount of clearance for the fan belt. Changing the belt is now a mammoth task, so I need to pop a new one on there (gonna place ANOTHER likkle order with Minispares today).
The only other thing that is a PITA is the fanbelt fitment, there's no way I'll be able to fit one without totally removing the existing radiator mount bracket. The fiddliness of fitting the radiator, working around the bottom pulley and also the timing cover has convinced me that a flip front is definitely on the cards when the engine is finished off and has been run in. I am tempted to do a steel flip front, but am as yet undecided. Whichever way I do it, it will be mounted so that it hinges forward, but has QR hinges, so it can be taken off in seconds rather than minutes. I have some amphenol multiplugs (thanks work :proud: ) that I can use for the lights etc. so it's all quite an easy mod really (apart from painting the front end).
Anyway, pics:
Fitting radiator/hoses
Marking out breather hoses for later fitment of catch tank
As Westwood would say 'Dat is TITE' :closed:
Marking out the CF bonnet for bonnet pin holes etc.
@Mini93, yes, the piccies are off my camera phone! :blink: Look at their bluriness! :genius:
#345 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 30 April 2007 - 03:39 PM
:proud:
