With regard to the Vented drive flanges.
Its a bit of a grey area unless you ask minisport themselves. The KAD 7.9" vented four pot calipers are specificaly designed for use with the Mini drive flange, the caliper has a different lug off set and the disks are modified for clearance of the hub.
I would expect that Minisport 'should' have designed this caliper in a similar way, but you never know, it is Minisport.
You may need the vented flanges, which will push the wheels out about another 5mm each side, i dont know the actual figure.
Best phone Minisport
If you have the ability, you could machine out the discs and maybe a little on the hubs and space the caliper back to achieve what KAD do, if the minisport calipers are not designed as such. other than that its no biggie fitting the vented flanges, you will have to machine of the locating lugs though, if they havent already been, or, Minispares do an uprated steel flange that doesnt have the lugs to start.
Oh and there are specific screws for the vented flange, they changed them so that a bolt on situation could never arise, parts wouldnt fit alerting you to the incorrect parts being fitted, that was mainly for ye ha's out there sevicing standard cars.
Phone Phone Phone
Edited by Mini Sprocket, 27 March 2007 - 09:45 AM.
