Aftermarket fuel gauge wiring
7 replies to this topic
#1 RacingGreen
RacingGreen
  • 2,111 posts
Posted 03 December 2006 - 06:20 PM
I've been looking at different types of fuel gauges for when i fit a new dashboard.
The gauge need 16ohms to read empty and 158ohms to read full. I wanted to know is there anyway i can give the gauge the correct ohm ratings so it will read correcty?
Mike
#2 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 03 December 2006 - 08:16 PM
a smiths one should read the same way!! not sure about a tim gauge!!
#3 RacingGreen
RacingGreen
  • 2,111 posts
Posted 04 December 2006 - 07:21 PM
The smiths should read the same a the original gauge?
What i really wanted to know though,is how to make up the correct ohms incase the gauge i use doesnt read correctly?
Mike
#4 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 05 December 2006 - 01:57 PM
You have to get the matching sender unit for it, you could probably create some sort of circuit to alter what resistance the original sender puts out across the range but I havent got the foggiest how you would set it up !
#5 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 05 December 2006 - 02:18 PM
you can use resistors or a potentiometer(variable resistor)
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 05 December 2006 - 03:04 PM
Er... no.
I suppose the very late Mini sending units may be different, but.... All the post 1964 sending units I've seen operate between a nominal 240 ohms empty to 30 ohms full. You can narrow that range by adding parallel resistors... but you can't change the direction. (240-30 vs 16-158)
If it's not too late, go back and select a different, matching gauge that accepts the input range of the Mini sending unit. If you have a volt/ohm meter check your sending unit directly. Mark and disconnect the wires on the side of the tank. Connect the volt/ohm meter and set it to measure resistance. Use a flashlight to look in the tank through the filler neck and use a bent coat hanger to lift the float arm to the top while watching the meter. Repeat this by pushing the float all the way down. Buy a gauge that comes closest to the range you just measured.
#7 RacingGreen
RacingGreen
  • 2,111 posts
Posted 05 December 2006 - 07:18 PM
thanks DK, i havent bought the gauge yet, so i will find one which suits the sender, i just wondered how i would go about getting it to read correctly.
Mike
#8 fikus01
fikus01
  • 1,910 posts
Posted 06 December 2006 - 01:28 AM
its a mini get a torch and have a look in the tank anything else is an electronically calculated guess!!!!
