My daily drive
#31
Posted 15 February 2008 - 01:22 PM
Tom you muppet. You alright? What made you decide to take up hedge trimming?
#32
Posted 15 February 2008 - 01:27 PM
#33
Posted 15 February 2008 - 01:33 PM
At least its not your van. And even if it was, you'd sill finish before dog
#34
Posted 28 May 2008 - 09:45 PM
Right, heres the damage caused by the crash:
Front panel, wing, A panel all bust, I'm guessing the subframe is as well, along with the steering rack. The door gap has closed up slightly as well, but I have a mate with a porta-power I can borrow to press it out with.
The first task was to evict the excess motorbikes, invalid scooter and wheelchair that had appeared in the garage, and move the headlamp tester and winch out of my way. This leaves me with enough room to keep both minis in the garage, bonus!
Until I can get some extra muscle here to give us a push with it, I'm starting to clean up parts to bolt onto it when I start:
Cruddy old callipers:
And with new seals, pistons and a lick of finest halfords red paint:
Stripped and painted driveshafts, ready for new CVs and pot joints:
And on the way home from working up in Durham a few weeks ago, I called into M-machine and got this little lot:
The plan is to get it in the garage, new steering rack and subframe, zap a new front end on, new arches, probably wheels as well, respray and full rebuild. Not much then...
#35
Posted 29 May 2008 - 04:53 PM
tis a shame it happened but hey ho! bigger better things?
#36
Posted 29 May 2008 - 05:01 PM
lucky!
2 lifts??
#37
Posted 29 May 2008 - 05:32 PM
respray? what colour?
always has to be the 1st question
Same colour - I really like it, and it means theres not as much prep work
dude, is that your personal garage at home??
lucky!
2 lifts??
Yep, thats my garage, in the back garden. Theres a 4 post lift in the other bay as well, which is great for suspension setups. Its a hardship I guess, but I struggle along...
#38
Posted 30 May 2008 - 09:33 PM
#39
Posted 30 May 2008 - 09:40 PM
thought of you today - roofless spat a cog at the croft services
#40
Posted 31 May 2008 - 10:05 PM
Well, the eagle has landed! Shoved it into the garage tonight, so the project has officially begun now.
I went and picked up the new radius arms as well:
Helluva a lot quicker and easier than doing them yourself!
And got the rad out, carb off and all the wiring disconnected:
If I can get a good day on it tomorrow I should get the engine pulled out, and loosen the subframe ready for that to drop when I've got the new one ready to go on. Its a good job I was going to pull it off the road anyway - found a couple of bits that wouldn't have lasted much longer. Big flap of rubber hanging off the clutch hose being one
#41
Posted 31 May 2008 - 10:29 PM
#42
Posted 31 May 2008 - 10:33 PM
#43
Posted 31 May 2008 - 11:04 PM
#44
Posted 02 June 2008 - 09:20 PM
And then pushed the car to the back of the garage. In the safest possible way
Once it was at the back I put the arms back on the ramp and got it up in the air, then undid the subframe. And a sodding brake calliper that I'd carefully tucked up on a tie bar fell off and twatted me on the head
Also picked a recon steering rack for the bargain price of £22. The one thats on the car is cracked, and the bulkhead where it mounts to has bent a bit
And finally - all the hubs are stripped down ready for new bearings:
#45
Posted 03 June 2008 - 09:32 PM
