My Project. '78 Saloon Full Rebuild
#46
Posted 10 February 2007 - 07:08 PM
the cars very different to when it left yours
lol the only problems were the cuts you'd made in the 2nd xmember and the cut in the parcel shelf, but was no trouble to weld them up.
got the rear shocks on, need some spacers adn longer studs for the rear, but will have to get the front built up first to check the track.
J
#47
Posted 10 February 2007 - 09:50 PM
#48
Posted 10 February 2007 - 10:33 PM
Huddersfield Mini Spares
it works out cheaper if you order the coilovers from HS and the brackets from Minispares
projects looking good mate, youll have to send me some pictures/email/whatever when you get round to mounting your rear subframe.
#49
Posted 11 February 2007 - 03:35 PM
as i havent got much to do at the moment thought id take some pictures.
metro vented disc drive flanges machined and studs back in ready to bolt up.
started on the wiring loom, looks a horrible job, especially from this picture, but its not really.
coilovers are on the back too.
J
#50
Posted 11 February 2007 - 11:11 PM
#51
Posted 13 February 2007 - 03:43 PM
I have some you can have for the price of postageneed some spacers and longer studs for the rear
#52
Posted 13 February 2007 - 05:32 PM
how big are the spacers?
i wont know how much spacing ill need until the front wheels are on.
how much will the postage be then?
J
#53
Posted 13 February 2007 - 08:50 PM
#54
Posted 13 February 2007 - 09:08 PM
looking good, and that rear subframe set up looks wicked, im almost tempted to do it to mine.
cheers mate, if your going to use coilovers why not? cheaper than buying a "beam" and you know its gonna fit.
J
#55
Posted 13 February 2007 - 10:58 PM
J
I'm blind as a bat. Does this setup do away with the rear sub altogether? Or does it need bracing somewhere?
#56
Posted 14 February 2007 - 12:56 AM
#57
Posted 14 February 2007 - 12:09 PM
what hes done is chop down the rear subframe so that technically it can rotate so to stop the subframe rotating he has fitted some bolts through the heel bourd and upto the subframe hope thats right anyway and i hope you dont mind me answering that $way
thats bang on.
#58
Posted 14 February 2007 - 07:56 PM
#59
Posted 14 February 2007 - 08:32 PM
not using coil overs though, plus i dont really fancy chopping up a brand new heritage frame!
if your not using coilovers you have to have the whole frame to house the doughnut and trumpet...
arent you putting in a carbon boot floor MOWOG? does this get rid of the rear mounts or not?
Edited by $way, 14 February 2007 - 08:33 PM.
#60
Posted 14 February 2007 - 08:43 PM
