Centre Console Plans
Posted 24 November 2006 - 09:56 PM
Guest_iansmini_*
Posted 03 April 2008 - 10:56 PM
Posted 04 April 2008 - 01:10 PM
Posted 10 June 2008 - 06:10 PM
right before using it as a template
I scanned the template into 5 seperate peices for some one else so they could print it out onto A 4 paper
(they never let me know if it worked?)
So here they are hope it helps
This is how mine turned out
Posted 11 June 2008 - 12:32 PM
Posted 29 June 2008 - 09:38 PM
Posted 07 October 2008 - 07:13 PM
Mini Centre Consoles
Hope this Helps.
Posted 17 May 2009 - 06:47 PM
Posted 03 October 2010 - 07:00 AM
Posted 03 October 2010 - 07:42 AM
this may be a silly question but does anyone know if the centre console restricts the heater output?
It will do unless you provide adequate outlets for the heat to vent out into the car. Mine has a heat resistant "heater board" between the existing heater outlet and the main part of the console to deflect the heat forward and toward two multi directional air vents on the front facia of the console (effectivley making an air duct). This also stops any items placed in the storage area of the console from getting hot and being damaged by the hot air. It's all going to depend on the design of your console, a good quality, well developed and proffesionaly built console will take account of these sorts of issues, where as the lower end of the market and DIY versions may, or may not do so.
Similarly a well developed/designed console will tend to use plastic or waterproof trim at all the points where the console comes into contact with the vehicles carpet, as this stops the console absorbing moisture from the carpet caused by wet shoes.
Edited by AVV IT, 03 October 2010 - 07:47 AM.
Posted 25 June 2011 - 09:40 PM
Posted 29 April 2012 - 11:36 AM
Thanks.
