Do Float Chamber Lids Warp?
4 replies to this topic
#1 floormanager
floormanager
  • 683 posts
  • Local Club: Mini Club Sussex
Posted Yesterday, 08:30 PM
Hello,
I've recently had trouble with a seeping HS2 float chamber gasket.  I replaced the gasket with an official SU gasket but it took a few attempts to seal (new gasket each time).  I'm wondering if the lid has deformed over time, with the areas around the screws bottoming out before sufficient compressing force has been achieved.  Any thoughts?
Paul
Edited by floormanager, Yesterday, 08:31 PM.
#2 DeadSquare
DeadSquare
  • 3,095 posts
Posted Yesterday, 11:15 PM
YES.
The alloy is cheap casting rubbish, not even fit for making Dinky cars.
To test your hypothesis, use valve grinding paste to treat the lid as though it is a valve by rotating it on the float chamber, to show the high spots.  You might be lucky and grind out the leak.
As a bodge, thin smear of bath caulk on both sides of the gasket
#3 68+86auto
68+86auto
  • 905 posts
  • Local Club: Queensland Mini Car Club
Posted Yesterday, 11:37 PM
It's probably been over tightened. They don't need to be very tight. There's no pressure that it needs to hold, it just stops any fuel that splashes around.
#4 floormanager
floormanager
  • 683 posts
Posted Today, 07:31 AM
Thank you for your suggestions, I will try and test.  I should imagine they have been overtighted (by me even to stop the bloody leak).  New lids are expensive and I wanted to make sure I was not wasting money unnecessarily.  I like the valve grinding paste idea.
Paul
#5 68+86auto
68+86auto
  • 905 posts
Posted Today, 07:41 AM
Paul
You could sand it flat using sandpaper on a piece of glass
