Minispares "torquemaster" Fouling On Inner Two Nuts - Cannot Tighten
9 replies to this topic
#1 CdnAustinAmerica
CdnAustinAmerica
  • 49 posts
Posted Yesterday, 12:07 PM
Had some problems with my other manifold so I got the minispares "torquemaster" manifold to use instead and I cannot tighten the innter two nuts, access is fouled by the manifold, either with the short or long brass nuts!
The socket fouls against the manifold - using a shot nut and a "wobble" extension I could start to tighten it but it also locked the socket itself against the manifold.
This seems like a design oversight on something they claim to sell 900+ of a year. The other manifold I had was at least easy to get off and on.
Also I would like to add that the stud holes for the carb were not straight at all and I had to waller out my spacer a bunch to get it to fit. This is not the first time I've had quality problems with a minispares item recently. I'm glad they make just about everything but in general I don't mind paying more if it means the quality is there, I'd rather not spend my time fettling to make new parts fit!
#2 nicklouse
  • 18,581 posts
Posted Yesterday, 12:56 PM
What size drive do your sockets have?
#3 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted Yesterday, 01:17 PM
Have you compared the thickness of the inlet and exhaust manifold faces? You might need stepped washers.
#4 Shooter63
Shooter63
  • 1,027 posts
Posted Yesterday, 03:05 PM
You normally need 1/4" drive sockets with a wobble joint and extension for those bad boys, cheapo thin wall sockets are good if you have any, also cutting off the lower tangs/ears on the manifold helps alot as you can have the fat, spring washer and nut engaged onto the stud, then just slide the manifold into position, a couple of turns with the aforementioned socket does the job.
Shooter
#5 absx2
absx2
  • 910 posts
Posted Yesterday, 03:09 PM
Crikey, I thought they changed the design a long time ago.
A real bad piece of design really as there is enough meat there to mill out some clearance which is what I did on the last one.
#6 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted Yesterday, 04:39 PM
I used to have torquemaster inlet, and the only way I could do the inner ones up was with a spanner
#7 CdnAustinAmerica
CdnAustinAmerica
  • 49 posts
Posted Yesterday, 05:13 PM
I have 1/4 inch
its not the flanges, those are actually pretty good, its the intake runner itself.
I might have to sacrifice a spanner and shorten it then
#8 Spider
  • 14,846 posts
Posted Yesterday, 06:31 PM
I use 1/4" Drive Sockets and a 13 mm socket here, just gives that extra bit of movement and is easier to get the socket off when done up.
No help here, but for my own car, I made some very long nuts, you can do them with a spanner.
#9 CdnAustinAmerica
CdnAustinAmerica
  • 49 posts
Posted Today, 07:00 AM
Thanks! This actually worked somehow with my wobble extension, had to put the long nuts on other studs and use the shorter brass but its on now.
Those studs not being straight though.. Had to file my abutment plate and spacer to get them on.
Now its leaking where the hoses go for some reason. Oh boy.
Edited by CdnAustinAmerica, Today, 07:00 AM.
#10 Designer
Designer
  • 582 posts
  • Local Club: LSMOC
Posted Today, 07:39 AM
hi,
Reason number 2006 on why we love our Minis so much.
Paddy
8 user(s) are reading this topic
2 members, 6 guests, 0 anonymous users
    Java_Green, mc550
