Fuel Tank Sender Unit
#1 Peter_NottinghamS
Peter_NottinghamS
  • 36 posts
Posted Yesterday, 09:33 PM
I'm working through a list of niggles and frustrations and one issue - the constant whiff of petrol - has remain unsolved. Until today, I hope.
I've followed the fuel lines from back to front and failed to find any leaks but today I removed the spare wheel to check the spare wheel tyre pressure, and the wheel well contained a sticky film of what clearly smelt like stale petrol.
I've been keeping the fuel level low in the tank and relying on a 5-litre back-up plastic can in an attempt to keep down the cost of lost fuel, and although I'd taken a cursory glance at the sender unit, didn't notice any signs of leaks.
But upon close inspection, the sender unit circular 'base' seems to have two raised edges, as if someone has used a screw driver to free the unit.
The photo isn't desperately clear but is it just me?
Should the circular plate be flat all around it's circumference.
I've ordered a new seal and clip but I fear the sender unit plate may be distorted and hence leaking when the fuel level rises above the sender unit level.
Thoughts?
I suspect I'm going to need a new sender unit?
Thanks in advance.
Peter
Edited by Peter_NottinghamS, Yesterday, 09:34 PM.
#2 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted Today, 07:59 AM
To be on the safe side I would order a new sender and also check the over flow / breather pipe make sure it's ok
#3 sonscar
sonscar
  • 2,995 posts
Posted Today, 08:07 AM
Do you know how the seal works?there is a seal under the sender then the sender and lastly the ring with the little ears which has long tapered ramps.this ring has cut outs which drop over dimples on the tank and then tap round to use the wedges to compress the seal.The seals can harden and leak.Steve..
#4 MiniMadRacer
MiniMadRacer
  • 888 posts
Posted Today, 11:14 AM
While you are at it, it may be wise to change the flexible fuel pipes for E10 friendly ones, (assuming you have not already done so), especially if you are using the E10 unleaded fuel, as it will rot out the "old" pipes pretty quickly.
