I got the engine and box already stripped down with buckets of bits.
On my primary gear was a ring with small teeth on it. It looks like it should go up against the primary gear teeth, where the oil holes go perhaps, but having consulted Haynes, videos and part lists I can't see it anywhere....
Should it go on? It's tight so will need a light drift to get it on, but why is it there?
Thanks.
