The exhaust is blowing at the Y-joint (the pictures shows the leakage) and although the exhaust still seems stable there is no attachment/bracket securing the exhaust system.
I've identified a bracket - Exhaust to Gearbox (1985 on) Manual (part number GEX7526) but can't find an image of such a bracket is attached (to the gearbox) and to the exhaust.
I've spent 20-minutes searching the topic on the forum but I can't find a suitable answer.
Does anyone have an image or advice?
Also, while underneath, I identified the gear change rod has lots of play where the 'bayonet' style joint where it connects to the gearbox.
Gear changes seem okay but I suspect it has far too much play.
Should this joint be loose and sloppy? I suspect not.
Thanks in advance.
Peter
Edited by Peter_NottinghamS, Yesterday, 08:05 PM.
