Selling My 93 Cooper Project (Ebay Link)
No replies to this topic
#1 exuptoy
exuptoy
  • 674 posts
Posted Yesterday, 08:05 AM
Hi guys, selling my 93 Cooper as I need the space.
Owned since 2020, front end, scuttle, door frame, quarter floor, rear lower OS quarter and corner of roof and A post all removed and replaced with Heritage stuff.
All inner wings, flitch, scuttle closers properly repaired with seam sealer applied before covering with Zinc rich primer called bonda. A panels still to fit once the a pillar returns are finished to give something for the a panels to attach to.
I’ve linked the eBay add below and price is firm due to what I’ve spent on panels. Still have an M-Machine door skin and door bottom to go with the vehicle. It was complete when it arrived so everything present. Starts on the button and a Keith Calver timing chain fitted but clutch is stuck on (a few heat cycles may cure that) and clutch slave wont supply pressure so there’s a new slave and Goodridge line supplied.
£2500 firm or I’ll keep it and finish it when I get round to it.
Needs to be collected from south wales. Sold my last one to @shifty on here so maybe he can confirm I’m no bodger.
I can put pics up if people need them. I also have a chassis filter under the car if anyone wants to see the underside. It’s not bad in all honesty although I’d maybe remove the rear subby and give it a clean and coat of POR15 or similar and you could obviously check it before replacing with new hardware.
https://www.ebay.co....emis&media=COPY
Edited by exuptoy, Yesterday, 08:08 AM.
