Oil Change Recomendations
Steam
, Apr 17 2025 11:13 PM
6 replies to this topic
Posted 17 April 2025 - 11:13 PM
Why is there a time factor in oil change frequencies as well as a distance. Surely oil does not deteriorate appreciably over time.
Posted Yesterday, 04:08 AM
Apparently the additives do have a shelf life.
Posted Yesterday, 07:07 AM
If you search on YouTube for a channel called The oil Geek which is run by a guy called Lake Speed ( real name and a great one at that) he tests oils in every possible way, I'm pretty sure he did one on oil shelf life, all his content is fact based and test proven. The guy can get on your t#ts a bit but stick with it and the knowledge is there.
Shooter
Shooter
Posted Yesterday, 01:31 PM
How I understood it is the oil has additives to remove the carbon which slowly makes it acidic. I usually change mine every 1000 miles or every year at the latest (usually before storage).
Posted Yesterday, 02:27 PM
For the sake of 30 quid or so I’m happy to change the oil every year-probably only do around 1500 miles but considering the gearbox shares the oil with the engine it’s well worth it imo
Posted Yesterday, 03:25 PM
If you do fewer miles you're likely to do more of them with cold oil, in lower gears with more acceleration & gear changes. I look at it as just 2 different methods of estimating when the oil's service life is up - whichever you reach first.
Posted Yesterday, 07:27 PM
Living where I do even short runs are at highway speeds and ebgi e always gets up to temp, maybe not for long but probably long enough to drive off the nasties in the oil. Not being daily drivers the classics I have always reach the time expiry way before the distance. While I don't mind paying for oil and filters I do object to changing out fresh lokking oil. I apply a dose of common sense and judge the changes to suit.
