Inline Water Temp Sender, What Degrees?
4 replies to this topic
#1 blackbelt1990
blackbelt1990
  • 2,610 posts
  • Local Club: Minimus Maximus
Posted 14 April 2025 - 07:10 PM
Those of us with 90s minis know that the fan switch in the bottom of the radiator is useless. I’ve been through loads of them in the last 15 years or so.
I’m going to replace it with an inline one in the bottom radiator hose but I can’t decide what temp to use. I know it’ll rarely come on as I’ll still have the mechanical fan but I don’t want to over cool it!
The minispares one says it operates between 92 and 82 degrees, isn’t this a little low considering the car has an 88 degree thermostat?
Edited by blackbelt1990, 14 April 2025 - 07:12 PM.
#2 blackbelt1990
blackbelt1990
  • 2,610 posts
Posted 14 April 2025 - 07:44 PM
Or do I just move the standard one 🤔 they’re not mega reliable.
Edited by blackbelt1990, 14 April 2025 - 07:45 PM.
#3 brivinci
brivinci
  • 1,168 posts
Posted Yesterday, 03:53 PM
I would buy a new rad that replaces the old temp sensor with the screw in type you have listed above. I bought mine from Spares ages ago and the sensor has worked without issue. Also keeps the wiring in the same place. Not hacking or the need to add additional things that could fail.
#4 nicklouse
  • 18,555 posts
Posted Yesterday, 06:39 PM
It where you put it and how you use the engine. Before the heater return I would have the fan coming on around 90 degrees.
now you want to ask the question as to what those temp number actually mean.
i am guessing the first number is when it turns the fan on, and the second is when it would turn the fan off.
#5 brivinci
brivinci
  • 1,168 posts
Posted Yesterday, 07:20 PM
That is usually what the numbers mean, and I know it is the case for the one sold by Spares.
