If he already has the carbs and a stage one kit (as per the first post) then there’s potentially not a huge amount of costs to get them running nicely
They will give no performance increase, you may even experience a loss in performance as you will lose air speed in the induction side. You will also need a new exhaust manifold unless you cut up the original cast manifold if they will fit. Fitting the new exhaust manifold will really need a suitable exhaust system.
Hi all,
I have recently acquired a pair of HS2’s but will they work on my 998? The engine is completely standard apart from a stage one kit. I’m not looking for any performance increases as I know they won’t have much impact, it would simply be for the aesthetics.
and after all that the carbs will need setting up to run correctly. All in all a lot of cash just for looks and more noise in the cabin.
Twin Hs2’S On A Standard 998?
Uncle Bobby B
, Apr 13 2025 08:23 PM
15 replies to this topic
#16
Posted Today, 12:14 AM
