I checked the compression and 160 ISH across all cylinders.
So confused!
More checks today, tappet chest covers tightened up as a little loose, check float levels, manifold gaskets,tightened and inspected all fuel clips,jets checked..
As mentioned without the breathers connected to the carb it runs fine, if I block off the carb connections it drops the afr to 8...
Edited by petey81, 18 April 2025 - 11:50 AM.
