Bias Pedal Box Question
7 replies to this topic
#1 Gaz66
Gaz66
  • 886 posts
Posted 11 April 2025 - 05:14 PM
Is there anyone on here using a 3 cylinder bias pedal box such as the obp one?
If there is.... what size cylinder are you using for the clutch?
#2 nicklouse
  • 18,555 posts
Posted 11 April 2025 - 05:48 PM
Using the KAD one.
designed for the Mini pedal box so the leverages will be different.
#3 Shooter63
Shooter63
  • 1,023 posts
Posted 11 April 2025 - 06:50 PM
The clutch bore size doesn't change, so .750 will do the job, as a side point, it was and still probably is illegal to run a bias box on the road which is adjustable and was an MOT Failure, you had to set it up and pin/weld it. If you think about it a turn the wrong way could load the rear brakes meaning when you hit the brakes the next thing you know you are backwards in a hedge or worse
Shooter
#4 Gaz66
Gaz66
  • 886 posts
Posted 12 April 2025 - 04:02 PM
Another angle on the clutch....
Will putting a smaller bore cylinder in make the clutch easier to operate or will there not be enough fluid moved then to operate it fully?
#5 imack
imack
  • 2,098 posts
Posted 12 April 2025 - 04:21 PM
I'd imagine it's not going to push enough fluid to operate the slave cylinder fully. What clutch/flywheel set up do you plan to use?
#6 Gaz66
Gaz66
  • 886 posts
Posted 12 April 2025 - 04:26 PM
It's going to be a pre verto setup with grey diaphragm
#7 nicklouse
  • 18,555 posts
Posted 12 April 2025 - 04:43 PM
Smaller will make it easier but you will have to move it further.
#8 nicklouse
  • 18,555 posts
Posted 12 April 2025 - 04:53 PM
The one from KAD has the green tag. This will give you the bore size.
