The new 1275A replacement engine does not have a breather can on the timing cover like my older 1275A. There is just the clutch cover breather can. My understanding was that the HIF44 carb's breather tube should tap into a clutch cover can and a can on the front of the engine. Is there somewhere else I should attach a vent into like the mechanical pump cover plate, or is it okay to just use the single clutch cover breather can?
1275 Hif44 Breather System
crock
, Apr 10 2025 05:16 AM
2 replies to this topic
Posted 10 April 2025 - 05:16 AM
Posted 10 April 2025 - 07:16 AM
Mine is currently set up only with the flywheel/clutch cover breather and no issues so far
If you could get a baffled rocker cover breather port that’s another option
Posted 11 April 2025 - 11:25 AM
should be fine with just the one
