Reacquired my old mini from someone that bought it from me as an MOT'd driving project ~12y ago and never moved it off their drive. It's a 998cc auto, needs a full recondition, and I'm resuming my plans of doing my first engine swap + rebuild. For me a mini needs an A series, so I'm keeping my eye out for a carby model A+ 1275 manual, I'll be rebuilding it, paying someone local for skimming/boring, megajolt kit, and eventually get it rolling roaded naturally aspirated. The aim is a fast road carb 1275, and I live right by Donington so it'd be rude not to do one or two days in it.
Everything sounds straightforward so far, but eventually I will want more power. I usually ride sports bikes, and whilst it'll never be on par with that, I don't want to be stuck behind someone doing 40mph on an A road and unsure whether I've got the power to pass, I want to feel a bit of being pushed in to the seat when I floor it. Numbers wise, I like to focus on bhp/ton, so if we assume the car is 700kg then 85bhp, which I think would be achievable with the above setup, gets me 120bhp per ton which is on par with a Ford Fiesta 1.6 Zetec S 2008, still fun in the classic mini, but could be more exciting...
This leads me obviously to forced induction. I've always wanted to turbocharge a car to experience the whooosh of the turbo coming on, and I love the noise, but I'm doing my first engine swap + rebuild, so adding a turbo on top is a lot to learn all at once, and I'm workin to a budget. It'd be ideal if I could rebuild the engine and run it N/A for a year or two, and then add on forced induction later. All the reading I've done suggests that my best option in this case would be a supercharger instead of a turbo, as I wouldn't have to change the pistons/cam for the turbo later on - I can build an N/A now and bolt a supercharger on later without having to get the engine in bits again and replace 1-2y old parts.
If I could get 140bhp, that puts it at ~200bhp/ton, which is on par with a 2020 Audi A4 S4 3.0 V6 Turbo, which is a bit more respectable.
I'm aware of certain upgrades around oil pick up, centre strap, x pin etc, but I read a lot of conflicting info around whether or not the standard gearbox would be good for ~140bhp or more. Part of me wants straight cut gears, but I ran a Tyga Maggot exhaust on a VFR400 for a while and I can still feel my ears ringing, I'd hate to rebuild and get it going, then realise I can't stand it after a month.
I'd like to run N/A for a bit first, so is the supercharger later the best route (vmaxscart most likely)? Or just suck it up and save for another set of pistons + camshaft and turbo it in future?
Yet to start work on the car and it has holes in the floor and needs tons of work before I get to the engine, so I have time to learn and plan. Any advice etc welcome!
