Engine Died. Some Internet Diagnosis Please?
42 replies to this topic
#16 Designer
Designer
  • 582 posts
  • Local Club: LSMOC
Posted 05 April 2025 - 12:58 PM
Hi,
Check the connection between the black wire coming out of the dizzy and connecting to the white wire with black tracer(or black wire with white tracer which ever way you see it).
I had similar problem and a bad connection there was the culprit.
Paddy
#17 bluequinn
bluequinn
  • 98 posts
Posted 05 April 2025 - 05:12 PM
Here’s the inside of the dizzy. Not much access or time to do more than that today.
New points and condenser in 2016. That’s long enough for them to go bad but it hasn’t done that many miles in that time.
How can I test this? Just test for spark or something multimetery? I have never had a vehicle with points before.
If I’ve got to replace them I’d be daft not to change for electronic ignition, right?
#18 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 05 April 2025 - 05:36 PM
That cam pad looks mighty dry. That'll accelerate the heel pad wear, a lot.
Check the points gap. I won't be surprised if it's closed up from the ideal.
#19 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 05 April 2025 - 08:54 PM
The rotor contact also looks a bit corroded. You can scuff that up with a wire brush to get shiny metal on the edge and the centre. While you’re there, the contacts inside the cap need to be clean too
There’s lots of small items throughout the ignition system that can add up to misfires or no start when they’re worn or old
#20 Steam
Steam
  • 757 posts
  • Local Club: Victorian Mini Club
Posted 06 April 2025 - 06:20 AM
Nothing obviously wrong from your photo, check the points gap/dwell angle and condition of points contact areas. Then pull a spark plug or 2 out and reconnect to lead holding against the block with insulated pliers, see what the colour of thee spark is, should be strong blue white across the plug contacts.
#21 bluequinn
bluequinn
  • 98 posts
Posted 08 April 2025 - 06:36 PM
Ok, today I pulled all the plugs and gapped them to 25 thou. Two were too widely gapped. I also cleaned up the rotor arm, and the contacts in the cap, oiled the felt thing, and set the points gap to 15mm. I checked all the coil and dizzy wiring and it all looks Ok, but not perfect. The coil has been changed for a Ducelier one and there are a lot of heat shrunk adaptors for the different connections.
Anyway none of this did any good at all. It will not start.
The starter motor is very strong at least. There was also a good smell of fuel. And brake cleaner sprayed in the air intake didn’t work.
That’s about all the checking I can do without a glamorous assistant to turn the key while I check for spark.
Tomorrow a package of parts arrives, so I can service the carb. Judging by the plugs though the fuelling has been spot on. On Friday my wife returns from a work trip so I can do more checking.
I don’t think I have eliminated anything yet.
Edited by bluequinn, 08 April 2025 - 06:46 PM.
#22 bpirie1000
bpirie1000
  • Area Managers
  • 2,345 posts
  • Local Club: Amoc
Posted 08 April 2025 - 08:05 PM
Check the battery connections. Also the engine earthstrap is certainly worth checking, usually under the engine mount on left hand side of the car. Underthe master cylinder.
I would also say clean up the rotor arm connections.
Edited by bpirie1000, 09 April 2025 - 07:45 AM.
#23 68+86auto
68+86auto
  • 905 posts
  • Local Club: Queensland Mini Car Club
Posted 08 April 2025 - 10:28 PM
Please do not touch the carb until you KNOW what the problem is. If you do something incorrect during the rebuild then it will make more complications in order to get it running. You need to get out a multimeter and measure the voltages everywhere when trying to start it. You don't need an assistant, simply turn the key on and then make a connection between the starter battery terminal and large spade in order to crank. Make sure it's not in gear.
#24 bluequinn
bluequinn
  • 98 posts
Posted 09 April 2025 - 08:11 AM
Oh that’s game-changing advice. Thank you!
#25 bluequinn
bluequinn
  • 98 posts
Posted 09 April 2025 - 03:37 PM
OK, small update. I have 11 volts across the coil terminals when not cranking. As its a ballasted system it should be lower than that, right?
Would that be a condensor killer?
#26 Steam
Steam
  • 757 posts
Posted 09 April 2025 - 08:25 PM
Did you test for a spark with the plugs out, should be strong blue / white.
#27 bluequinn
bluequinn
  • 98 posts
Posted 09 April 2025 - 08:40 PM
I tried. I don't have the manual dexterity to hold 3 wires at once.
There were sparks, there was a pop, I decided it that discretion was the better part of valour.
I shall wait for my wife to return on Friday and she can be on key turning duties.
#28 68+86auto
68+86auto
  • 905 posts
Posted 09 April 2025 - 10:38 PM
If the points are open, you should see the battery voltage. If the points are closed, you should see lower than that. 11v indicates that your points are probably open and your problem is a bad battery or connection somewhere. See what voltage the battery posts are at with the ignition on.
#29 sonscar
sonscar
  • 2,997 posts
Posted 10 April 2025 - 07:26 AM
Treat the points as a switch,the cam lobes open the switch turning off the coil and making it spark.On off on off and so on.The rotor is also a switch rotating to send the spark to the correct plug.It is not magic.Steve..
#30 Earwax
Earwax
  • 487 posts
Posted 11 April 2025 - 10:12 PM
the one person alone underbonnet starter procedure ( as mentioned by 68 +86auto) is a winner.  Off track but possibly worth mentioning for the long haul in mini mechanicals
google       remote starter button tool - for the ultimate lazy sit on your stool and diagnose helper and relatively cheap. One of the autosparkies on here might be able to recommend some 'heavy duty' types or specs .
