Misfire 1275 Engine
5 replies to this topic
#1 Jonwill
Jonwill
    Starting My Mini Up
  • 1 posts
Posted 02 April 2025 - 06:00 PM
My mini has a misfire on cylinder 2 when I remove plug cap and arc to plug it fires. I've replaced plugs points leads cap anyone have any idea?Thanks.
#2 timmy850
timmy850
  • 3,294 posts
  • Local Club: MITG
Posted Today, 02:24 AM
Are the valve clearances set properly?
Have you done a compression test?
#3 68+86auto
68+86auto
  • 876 posts
  • Local Club: Queensland Mini Car Club
Posted Today, 04:03 AM
How do you know you have a misfire on cylinder 2?
#4 Lplus
Lplus
  • 883 posts
Posted Today, 06:54 AM
Not quite sure what you mean when you say when you arc the spark to the plug it fires.  Do you mean the engine then runs on 4 cylinders, or do you mean you can hear the spark jump to the plug but the engine still doesn't run on 4?
#5 timmy850
timmy850
  • 3,294 posts
  • Local Club: MITG
Posted Today, 06:56 AM
It’s a little trick to test the system. If you pull the lead off and hold it off the top of the spark plug it’ll make a wider gap, which can increase the spark power and make the plug fire.
#6 Lplus
Lplus
  • 883 posts
Posted Today, 04:25 PM
ok, I just wanted the OP to confirm that.
