Hello,
Just getting a classic mini ('78 Morris Mini 1000) back on the road again after 20 years.
It has all standard components, so no adjustment in suspension arms etc, and nothing in the rear. The only adjustment is the rod ends on the steering rack.
The 'Repair Certifier' who is a step in the process here of getting the mini back on the road again, requires me to get an alignment done prior to him doing his checks, just to see what the values are.
However, does anyone know what the standard values 'should' be?
If they are not 'in spec' anymore... assuming they ever were from factory, I am not sure what can be done - considering there is only adjustable toe in/out from the track rod ends...
Anyone have any idea?
All standard / original arms, just had new bushings, bearings, pins, rubbers, joints, cones, shocks etc put in the original upper/lower, rear arms, hubs etc, but its otherwise all standard hardware.
