At the beginning of winter I changed the following bulbs to LEDs.
All dash board bulbs including the Smiths time clock.
Interior courtesy light.
Number plate bulbs.
Everything on the rear clusters. The clusters were new also.
As I had changed the indicator bulbs the relay was changed to a suitable one also. The car wasn't really run and went into hibernation whilst I did bits of bodywork. First drive yesterday was 50 plus miles, with a stop for dinner, and two miles from home a 15 amp blade fuse blew taking out everything on the middle clock. Petrol guage, temp guage and the two lights that come on on start up. Drove the car home, found the blown fuse and changed it.
Started it up today and the off side rear cluster was out, along with a headlight I think. Pulled all the fuses under the bonnet, ten in total, all fine and none blown. Tried the car and everything bizarrely back on.
Out for a drive then pulling up at home, indicators/hazards out. This was another of the blade fuses blown (20 amp).
Back out after replacing, for a spirited drive, turning everything on and off to test if anything was going to blow. Returned without incident.
Is there any reason this would happen from fitting the LEDs? I thought the power they draw is less than regular bulbs. Can fuses just get past it? The two bladed ones that went were really old.
The pic is the set of fuses where this has happened so for. They are on the bulkhead, behind the air filter.
cheers, Daz.
