Valve Springs, Sizes Etc.
3 replies to this topic
#1 Avtovaz
Avtovaz
  • 1,225 posts
Posted 31 March 2025 - 07:05 PM
Just want to check this out, so im looking at these valve springs
according to chat gtp,
Mini 1275 Uprated Double Valve Springs (Cooper S Style)
  • Outer spring diameter: ~29mm - 31mm
  • Inner spring diameter: ~20mm - 22mm
  • Installed height: ~38mm - 40mm
  • Seat pressure: ~80-90 lbs @ installed height
Now, the reason i ask is im having my Lada head done, and i cant get outer valve springs, and also they would be like £90 for the set posted from estonia. Lada sizes according to chat gtp
Lada 2103 (VAZ-2103) Valve Springs
  • Seat pressure: ~70-80 lbs @ installed height
also
Lada 2103 (VAZ-2103, 1.5L OHV)
  • Typically, stock Lada springs have an installed height in this range, but it can vary slightly depending on the exact head casting and valve setup.
Mini 1275 Uprated Double Valve Springs (Cooper S Type)
  • Installed height: ~36mm - 38mm
  • The standard Mini single valve springs are usually around 35mm - 37mm, but the uprated Cooper S double springs are slightly taller, bringing them closer to Lada spec.
So is this looking right to you? i could shim up the Mini springs 2mm, and i think the cam ill be going for on the lada is 10mm of lift, i dont know what the max lift of the mini springs would be?
thanks
#2 NLinPEN
NLinPEN
  • 61 posts
Posted Yesterday, 01:27 PM
I'm not sure if there are many posters on this forum who are familiar with both Mini and Lada. I don't know how accurate ChatGPT is about cars, or that you might want to double check with other documentation or websites.
If these Mini springs are so much cheaper than the Lada ones you could take the decision to simply spend the money and buy them as an experiment. Unless the money for these Mini springs is too much for your budget.
#3 nicklouse
  • 18,522 posts
Posted Yesterday, 02:16 PM
Looking at the numbers the Mini springs are a higher poundage. Same free and fitted but different seat pressures.
but as you have alluded to it comes down to how far you can compress the springs before coil bind.  A stronger spring can either be a better material or a thicker material.
i would buy and trial fit and measure.
#4 Avtovaz
Avtovaz
  • 1,225 posts
Posted Yesterday, 04:25 PM
I know people do use them in the Lada, but what chat gtp said seemed too good to be true. Turns out it was, they are quite different, the stats for the mini ones are totally wrong as i suspected, but i could not find any stats last night. The guy sorting my head is just going to use the old valve springs, it was a precaution not a need.
