Australian Leyland Mini Engine Mismatch
4 replies to this topic
#1 Mk2Brett
Mk2Brett
    Starting My Mini Up
  • 3 posts
Posted 30 March 2025 - 03:10 AM
Hi All!
This is my first post on the forum, I've just picked up a mini and trying to get up to speed with all of the specs and need a bit of help with this one.
I have a 1973 Australian Leyland Mini Clubman S, from what I can understand, it should probably have a 998cc engine with a "99H" Prefix engine number. However, I have a 10YCTAH engine prefix which points to a Morris Mini K 1098cc engine. So what I am assuming is this mini has had an engine swap with a bigger Mini K engine installed.
Can anyone point me in the direction on confirming my theory?
Thanks all!
#2 Spider
  • 14,782 posts
Posted 30 March 2025 - 04:33 AM
Hi and welcome to the forum.
It should have an 1100 engine, with a prefix of 1015. These were a locally assembled 1100 engine.
It was after the move from Zetland and locally assembled stocks dwindled later in 1975 that they were fitted with a fully imported 998 engine, with a prefix of 99H.
The 10YCTAH would have come from a Morris 1100. These were also locally assembled.
#3 Mk2Brett
Mk2Brett
    Starting My Mini Up
  • 3 posts
Posted 30 March 2025 - 04:57 AM
Awesome thank you for the information! I can finally understand the puzzle as looking up the engine code to model was just not making sense.
Glad to have the answer now.
Thanks!
#4 Steam
Steam
  • 733 posts
  • Local Club: Victorian Mini Club
Posted 30 March 2025 - 05:11 AM
Adding to Spiders info it may have had a 1001, 1009 or 1010 prefix 1098cc engine depending on its exacrt build date.
#5 Mk2Brett
Mk2Brett
    Starting My Mini Up
  • 3 posts
Posted 30 March 2025 - 11:02 AM
Build date is 10/73 on the data plate
