Hs4 Choke Lever Assembly
3 replies to this topic
#1 daddums
daddums
    Just On Tickover
  • 9 posts
Posted 25 March 2025 - 10:58 PM
Ok, I've been a numpty. I had the carb off to service it and removed the choke lever, but now I can't manage to reassemble it again.
I think I've worked out how to fit the main return spring between the carb body and the lever, but I can't figure out how the smaller spring acts between the the two lever arms (one which the choke cable connects to and the other which connects to the jet assembly).
Whats-App-Image-2025-03-25-at-22-22-14.j
I'd be very grateful if someone could send me a pic or a description of what to do, I've been fiddling for hours now...
#2 ADRay
ADRay
  • 93 posts
Posted 26 March 2025 - 10:32 AM
looks like HS4?
it’s a pretty tricky job. Took me no less that 2 dozen times of winding that spring until I got it right.
#3 Ethel
  • 25,886 posts
Posted 26 March 2025 - 11:41 AM
The outer spring returns the cam that operates the fast idle, if it helps. It should produce less torque than the inner spring does in its rest position so the fast idle operates before any mixture enrichment.
#4 stuart bowes
stuart bowes
  • 2,072 posts
Posted 26 March 2025 - 11:57 AM
captain hindsight to the rescue..
when you're taking stuff like that apart it's always worth taking loads of pictures from various angles as you strip it down, it can be really useful for reassembly
there is a reasonably inexpensive book on SU carbs for maintenance and tuning and points of general interest https://www.amazon.c...s/dp/1855202557
Edited by stuart bowes, 26 March 2025 - 11:59 AM.
