Identify A Part In The Ignition System
Best Answer Abbot , 23 March 2025 - 12:45 PM
Thanks for the feedback guys.
I will leave it where it is for now as the with the new points etc the care seems to be running a lot better.
Go to the full post
7 replies to this topic
#1 Abbot
Abbot
  • 105 posts
Posted 23 March 2025 - 11:09 AM
Hi All
I have just bought a new coil, points and ignition condenser to freshen up the the ignition system om my 89 998 LHD Mini.
There is a part which is mounted on a bracket and fitted under the bolt holding the coil in place.  It has a single black wire that connects to the negative terminal on the coil.
What is it ?  I could not find it in any of the parts catalogues. Is it worth replacing with a new one?
#2 whistler
whistler
  • 1,788 posts
Posted 23 March 2025 - 11:17 AM
Probably a condenser to stop radio interference. Common practice to fit these years ago.
#3 Abbot
Abbot
  • 105 posts
Posted 23 March 2025 - 11:46 AM
It does look like a slightly larger version of the condenser inside the distributer
#4 nicklouse
  • 18,522 posts
Posted 23 March 2025 - 11:47 AM
You say you have bought a condenser? So it’s not like that?
pictures for identification then.
#5 alpder
alpder
  • 377 posts
  • Local Club: MCR
Posted 23 March 2025 - 11:53 AM
Does sound like a condenser. But the way it's wired means it is in parallel (i.e. duplicating) the condenser on the distributor. Personally, unless it is a factory-standard item, I would remove it: a condenser failing short-circuit will kill the ignition. Having a pair of them, instead of the usual single, doubles the chances of that happening.
Also, poor quality modern condensers (and points) seem abundant, and anecdotally seem also a common cause of breakdown. So they are items that are worth buying only from the best sources you can find - say a reputable distributor specialist, rather than from a generalist parts supplier. If the old (well-made) parts are working fine, I probably wouldn't even change them... but you have to wonder if the extra condenser was fitted because the 'proper' one - on the distributor - stopped working sometime in the past.
Edited by alpder, 23 March 2025 - 11:59 AM.
#6 Lplus
Lplus
  • 881 posts
Posted 23 March 2025 - 12:25 PM
this - if it's externally mounted on the coil bracket it's just for radio suppression.  Not necessary unless your radio crackles when the engine is running.
#7 Abbot
Abbot
  • 105 posts
Posted 23 March 2025 - 12:42 PM
Sorry don't have a site for loading images.
The one I bought goes inside the distributer.
#8 Abbot
Abbot
  • 105 posts
Posted 23 March 2025 - 12:45 PM   Best Answer
