How Much Slop On Hif Throttle Shaft? And Are These Seals Upside Down?
10 replies to this topic
#1 alpder
alpder
  • 566 posts
  • Local Club: MCR
Posted 22 March 2025 - 05:06 PM
I'm getting 0.2mm (8 thou) side-to-side movement in all directions on the throttle-lever end of my HIF38 carb shaft. Is this OK? A bit too much but bearable? Or crazy-too-much?
Also puzzled by the seals (one just visible below the dial-gauge tip in the pic). Although they are close-fit around the shaft, they also seem to be free-floating: nothing pushes them against the faces of the carb body. End-movement of the shaft therefore just pushes the seals outwards along the shaft, and they don't move back of their own accord, so leaving an air-gap. Am I misunderstanding how they're supposed to work?
Attached File  IMG_20250322_165209.jpg   33.35K   0 downloads
Edited by alpder, 22 March 2025 - 05:30 PM.
#2 alpder
alpder
  • 566 posts
  • Local Club: MCR
Posted 22 March 2025 - 05:23 PM
Even more puzzled by the seals, now I've started to remove them. I've never seen this kind of seal before, but... surely these are upside down?
Attached File  IMG_20250322_171909.jpg   38.73K   0 downloads
Attached File  IMG_20250322_171944.jpg   38.57K   0 downloads
#3 Lplus
Lplus
  • 1,004 posts
Posted 22 March 2025 - 06:42 PM
Yes they are inside out.  When in place the vacuum in the manifold holds them against the seal face in the spindle shaft hole.
#4 alpder
alpder
  • 566 posts
  • Local Club: MCR
Posted 22 March 2025 - 06:48 PM
Thanks, that sounds right.
Trouble is I've got maybe 1.5mm end-float on the shaft. If I push the seals tight, then shift the shaft to furthest extreme, then centre it (as it will do when the butterfly is closed)... even then I can still blow into the outside of the seal and hear air going through into the venturi. No matter how hard I blow, the seal doesn't re-seat. Maybe the vac has a hell of a lot more puff than I do? Otherwise I worry that the vac won't re-seat it either - the gap between seal and face is just too big to overcome.
#5 Lplus
Lplus
  • 1,004 posts
Posted 22 March 2025 - 07:05 PM
Yep the engine can suck way harder than you can blow.  That's the way they are made so I wouldn't worry too much.  You will always have some end float on the shaft when the throttle is open, the only time it has no end float at all is when the butterfly is tightly closed with no gap at all around it.
#6 sonscar
sonscar
  • 3,255 posts
Posted 22 March 2025 - 08:25 PM
Why would you have end float?the butterfly is round and the throat is a circle.Steve..
#7 alpder
alpder
  • 566 posts
  • Local Club: MCR
Posted 22 March 2025 - 08:31 PM
Once you open the throttle, the butterfly becomes a side-on disc (so almost a line) that's slightly shorter than the dia of the throat. Also, the throat has two 7mm-ish drillings where the shaft bushes fit, so the throat profile goes bigger than the circle at those points.
#8 timmy850
timmy850
  • 3,606 posts
  • Local Club: MITG
Posted 22 March 2025 - 08:40 PM
You can get full size seals that fill the gap between the body and spindle
JZX1994
https://sucarb.co.uk...dle-seal-1.html
From memory the “end float” is taken up once you put the return springs and throttle quadrant on.
#9 alpder
alpder
  • 566 posts
  • Local Club: MCR
Posted 22 March 2025 - 08:55 PM
JZX1994
Now, I really like those seals. For two reasons: (1) I can stop messing about with 3D printed parts to achieve the same thing and (2) I can take the rest of the night off because I can't reassemble the carb now until they arrive sometime next week. So... beer-time it is, then. Cheers :-)
#10 Lplus
Lplus
  • 1,004 posts
Posted 23 March 2025 - 09:47 AM
JZX1994
From my parts book there was a change in 1988.  I don't know if the bore of the seal housing was increased to take the seal though.  The HIF carbs I have are all pre 88. :shrug:
I don't think the throttle quadrant should be tight against the carb body when the butterrfly is fully closed.  I think there should be a small gap to ensure the butterfly doesn't fail to close to the idle stop.  ymmv
#11 timmy850
timmy850
  • 3,606 posts
  • Local Club: MITG
Posted 23 March 2025 - 10:01 AM
The larger seals fit my HIF44 fine, and it’s date stamped 1982. I don’t know if this applies to all of them
I meant it as the return springs themselves that keep it centred, the quadrant shouldn’t touch, but the spring on each side keeps it aligned
