Problem Reading Rpm With A Multimeter
11 replies to this topic
#1 Abbot
Abbot
  • 98 posts
Posted 16 March 2025 - 09:10 PM
You may see from other threads that I have been chasing problems with getting my 89 998 Mini up and running.
Checking and adjusting the engine settings requires knowing what RPMs the engine is doing.
I have a Gunson Automotive Multimeter UT105 with and RPM function.
I connect it as instructed, red to coil neg terminal, black to earth.
Set the dial to RPM 4 cyl
The instructions and the dial both say take the read out and multiply by 10 to get actual rpm
My problem is I do not believe the value that it shows.
3250 for an engine that feels more like well below 2000.
Has anyone got a similar experience or is it me that needs recalibrating
#2 sonscar
sonscar
  • 2,969 posts
Posted 16 March 2025 - 09:31 PM
Does it have a low and high rpm setting?My ancient gunsons meter has two rpm ranges.Steve..
#3 Spider
  • 14,761 posts
Posted 16 March 2025 - 09:59 PM
If you are running points in the distributor, it could be that they are not breaking 'clean' but giving a good arc. That can be from the condensor.
#4 Abbot
Abbot
  • 98 posts
Posted 16 March 2025 - 10:43 PM
I dont think so.  There is nothing in the manual and there is only the one dial.  the only options on the RPM selection is the number of cylinders
#5 Abbot
Abbot
  • 98 posts
Posted 16 March 2025 - 10:45 PM
Sorry I am not sure what that means.
Yes it has points.
Does that mean they could need cleaning or gap setting?
Or does the condensor need renewing?
#6 68+86auto
68+86auto
  • 851 posts
  • Local Club: Queensland Mini Car Club
Posted 16 March 2025 - 11:07 PM
Yes it has points.
See if they are clean and then set the dwell.
#7 Abbot
Abbot
  • 98 posts
Posted Yesterday, 04:46 PM
I seem to be running a parallel thread with commom issues
As suggested I set about cleaning the points and checking the points gap
Now the car will not start at all and there is no spark
I nust have dislodged something
#8 Spider
  • 14,761 posts
Posted Yesterday, 05:58 PM
At a guess here, you may not have gaped the points correctly and they may not be closing.
If you disconnect the distributor from the coil and go through all the separate parts with a multimeter on ohms, you'll soon find the issue. Assume nothing and test everything.
#9 Abbot
Abbot
  • 98 posts
Posted Yesterday, 09:15 PM
The points may not be correct but when i checked with a bulb the light was going on and off
#10 Spider
  • 14,761 posts
Posted Today, 02:35 AM
That'll be enough to get it running.
Have you tried with the distributor connected to the coil, opening the points (from closed) with an insulated tool ?  You should see a spark at the points.
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,728 posts
Posted Today, 11:00 AM
To be fair I have never had much luck with digital meters and conventional ignition systems including a snap on £450 automotive meter which was not much more than useless for decent rpm reading. In use old school timing light rpm reading or an analogue gauge. These analogue gauges are much better for this task.
Ac
#12 viz139
viz139
  • 659 posts
  • Local Club: Irish Mini Owners Club
Posted Today, 01:11 PM
There is a choice on that meter for 2 or 4 stroke, are you on the correct one?
