Smiths Digital Speedo
9 replies to this topic
#1 mrmeds
mrmeds
  • 240 posts
Posted 16 March 2025 - 06:13 PM
Had one of these fitted at my request by mini specialist about 3 - 4 years  ago - but I get a weird flicking of the needle back and forth every so ften !. it sweeps back and forth when ignition is switched on , as part of normal process , so assume this random fli king is down toa bad earth of bad live connection.
It is wired direct to 12v ignition lead apparrently , ( white ) according to instructions , but i'm not sure whre the earth goes,/ Before I start dismantling my interior and trying to follow wires - does anyone have expierinc e of fitting one of these personally ?
Anyone got any ideas as to the most likely earth point itr will be wired into ? - Thinking it could be a bad connection with body work of ground , which may or may not be near the actual speedo ? Tried following the wiring diagrams but struggling to work  them out ?
#2 tmsmini
tmsmini
  • 725 posts
  • Local Club: MOASF
Posted 16 March 2025 - 11:41 PM
Depending on which sensor you are using, it is possible that the shrink tubing they use to adapt to the speedo gear may be wearing out causing slippage.
#3 Spider
  • 14,761 posts
Posted Yesterday, 02:52 AM
I doubt it's a bad power supply from your description. If power is removed for all but the very shortest of time, they do the 'dance' again on powering up. A very brief power loss won't be noticed.
I've come across similar issues (needle flickering etc) and found it was the sender. They seem to be poor quality and don't last, even taking in to account the issue tmsmini had above (and yes, I have come across that too). Most of this type don't have any type of bearing or mechanical support for the magnet / shaft and just seem to flog themselves to death. A friend even had one start to smoke. Some are only rated for 5 Volts and the in-line type that Mini Spares are (were ?) offering were only 1 pulse per rev. so they wouldn't register until you are doing around 15 mph.
I haven't yet found a suitable off the shelf sender. Ideally, they need to be a minimum of 8 pulse or more in a Mini.
#4 tmsmini
tmsmini
  • 725 posts
  • Local Club: MOASF
Posted Yesterday, 01:45 PM
I have had them wear out as well. They flop around in a wide arc after removal. It is hard to believe that one is not available that fits Smiths speedos directly and is made well.
#5 Spider
  • 14,761 posts
Posted Yesterday, 06:10 PM
I gave up and made my own;-
#6 dotmatrix
dotmatrix
  • 420 posts
Posted Yesterday, 08:59 PM
interesting read as I have a new sensor from minispares on my shelf waiting for me to buy a smiths 80mm universal digital speedo.
Edited by dotmatrix, Yesterday, 09:00 PM.
#7 Midas Mk1
Midas Mk1
  • 5,770 posts
  • Local Club: S.U.N.M.C
Posted Yesterday, 09:02 PM
Highly recommend the haltech gps sender for these, super smooth and accurate.
#8 dotmatrix
dotmatrix
  • 420 posts
Posted Yesterday, 09:15 PM
also through a dense forest?
#9 Spider
  • 14,761 posts
Posted Today, 02:40 AM
The ones that had early on that have the cable coming off at right angles work for a while, but I found not ideal as they are only 6 pulse. The later ones, with the cable 'inline' coming out the back were uselss as they were on single pulse.
The GPS pick-ups are just about junk to me, we have loads of tunnels around here and I've found GPS signal around tall builds quite hit and miss. They are also not legal here, like for the same reasons.
#10 evoderby
evoderby
  • 92 posts
Posted Today, 05:21 AM
Fully agree, junked the crappy MS mechanical sender within a day…fitted GPS and never looked back. Legal? Well I guess my straight cut drops, maniflow big bore and 45dcoe are not exactly legal on drive by noise as well…especially when running tunnels :-)
