What Happens To Unwanted Automatic Engines?
14 replies to this topic
#1 lordyoung1980
lordyoung1980
  • 101 posts
Posted 16 March 2025 - 04:26 PM
Years ago I would swap out autos for manual units. No one wanted autos and manuals were easy to get hold of from Metros and others. I would happily junk a perfectly good auto engine down the scrap yard. Now decades later I'm on the look out for auto units. I have one that needs replacement, it's a 998 and gutless when it did work. I can see on various forums that people still swap them out. My question is, what are people doing with the old units now? Are they hanging on to them or putting them in the scrap still?
#2 Spider
  • 15,133 posts
Posted 16 March 2025 - 06:10 PM
The engines are fairly easy to convert so they can be fitted to manual gearboxes, this is what I've been doing to many of them.
The auto gearboxes though, are expensive for parts and so few people want them, I take a few parts from them and then junk them off.
#3 lordyoung1980
lordyoung1980
  • 101 posts
Posted 16 March 2025 - 08:24 PM
If only you were closer, I would have took some of your hands.
#4 68+86auto
68+86auto
  • 1,009 posts
  • Local Club: Queensland Mini Car Club
Posted 16 March 2025 - 11:13 PM
Most people unfortunately throw them out as they've got no idea. Most people don't even realise they are four speed.
I'd guess that most people call them slow based on one of three reasons:
- They've never even driven or touched one and have no clue.
- The engine was poorly tuned
- The transmission needed repair. Not a fault of the transmission design, things need maintenance.
I often get people wanting me to fix them but I'm not a business so don't have the time or space to do so.
Edited by 68+86auto, 16 March 2025 - 11:17 PM.
#5 68+86auto
68+86auto
  • 1,009 posts
Posted 16 March 2025 - 11:16 PM
I need parts.
Edited by 68+86auto, 16 March 2025 - 11:19 PM.
#6 mab01uk
mab01uk
  • 12,532 posts
Posted 16 March 2025 - 11:27 PM
Might also be worth asking on the 'Automatic Mini Register' Forum:-
https://autominiregi....proboards.com/
Underbonnet photo of the first automatic Mini prototype in 1962:-
https://www.theminif...automatic-1962/
Edited by mab01uk, 16 March 2025 - 11:32 PM.
#7 Spider
  • 15,133 posts
Posted 17 March 2025 - 04:36 AM
I need parts.
Next time I have one, I'll give you a shout.
#8 lordyoung1980
lordyoung1980
  • 101 posts
Posted 17 March 2025 - 07:50 AM
I joined the auto mini register forum a few years ago but trawling through tons of post about which oil to use and the arguments that follow became dull. Also when I asked for technical info I was given a pdf that gave my laptop a virus that it never recovered from. So I avoid it now.
#9 mab01uk
mab01uk
  • 12,532 posts
Posted 17 March 2025 - 07:06 PM
These PDF file manuals linked below are a useful technical info reference source for automatic Mini owners and can also be downloaded.
AP-Mini-Automatic-Transmission-Service-Manual:-
https://www.widman.b...vice-Manual.pdf
AKM4694-Mini-Automatic-supplement:-
https://www.widman.b...-supplement.pdf
Mini-auto-gear-box:-
https://www.widman.b...to-gear-box.pdf
Foulis-automatic-transmission-manual-Mini:-
https://www.widman.b...manual-mini.pdf
Also this 'Mini Classic Automatic' Facebook group maybe of help:-
https://www.facebook...4/?locale=en_GB
#10 CaymanMini
CaymanMini
    Starting My Mini Up
  • 1 posts
Posted 18 March 2025 - 02:49 AM
How do you fit the manual gearbox to the automatic engine?  i thought that couldn't be done.
#11 68+86auto
68+86auto
  • 1,009 posts
Posted 18 March 2025 - 06:27 AM
It's pretty easy to do. Fitting an automatic transmission to a manual block is what's difficult.
#12 Spider
  • 15,133 posts
Posted 18 March 2025 - 06:34 AM
Same bolt pattern, the gearboxes bolt straight up.
There's a couple of drillings that need to be done on to the block, a spacer plate fitted for the oil pump and a manual type oil pressure relief valve seat to swap over to.
A few hours work.
#13 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 18 March 2025 - 07:14 AM
I’ve got a 1275 auto block under my shelf for the future. I think someone had started to convert it for manual as it’s got a dipstick hole drilled
Unfortunately 1275 blocks stopped in Australia when minis and mokes went out of production in the late 70’s/early 80’s and we didn’t get Metros, so the auto blocks became a viable option
#14 mab01uk
mab01uk
  • 12,532 posts
Posted 18 March 2025 - 08:23 AM
1275 Auto Block - Convert To Manual (With Pics)
To fit a 1275 auto block to a manual, apart from drilling the dipstick hole, there are a few mods needed to oil plumbing:
1. Auto block doesn't have the drilling all the way from the oil pump to the relief valve.
2. Auto block has 2 holes in the relief valve seat `cotton reel' to let oil get into the main gallery, because the normal filter flange is blocked off with a plate- the motor's lube oil comes UP the banjo pipe from the auto trans to the motor.
3. Auto block pump mounting recess is .250" deeper than in a normal 1275 block.
AusMini Forum: Auto Block conversion to Manual article link:-
http://www.ausmini.c...hp?f=25&t=90470
According to one of the Mini magazines a lot of auto Mini blocks are also being converted in Japan where many of the Rover Minis sold were automatics.
Edited by mab01uk, 18 March 2025 - 08:26 AM.
#15 DeadSquare
DeadSquare
  • 3,187 posts
Posted 18 March 2025 - 10:37 AM
On some auto blocks, the, the "oil pump mounting recess" is the same depth as manual block, not .250" deeper, but I think that these blocks had no oil passage from the oil filter to the main oil gallery and were cast with insufficient metal to risk drilling the passage.
By tapping both the oil gallery at the timing chain end and a spacer inserted between the oil filter mounting and the block (that is wedge shaped so that the oil filter doesn't foul the subframe), I make an external passage from the oil filter to the oil gallery.
