I am restoring a 1975 Mini. The shifter hole was buggered up in mine, so I had to rebuild the tunnel section and I need to drill a propper hole for the new shifter. If you could measure from the crossmember to the center if the shifter I would really appreciate it. Thank you
Shifter Hole Location
TonytheTeacher
, Mar 13 2025 08:49 PM
1 reply to this topic
