Maybe No Thermostat, Is It A Big Deal?
Best Answer DClarke1954 , 14 March 2025 - 12:18 PM
Slow down a bit, you are making too many assumptions. Do not assume that the sender is actually properly grounded. You seem to have a multi-meter? So you can measure resistance? If so, please disconnect the cable from the sender and measure the resistance from the sender's connector to the car ground. That's the only way to confirm, instead of assume, that the sender is having proper ground connection.
Yup, I get you.   When measuring across the one currently installed in the car ( a GTR101 sender) it shows 1,520 Ohms between connector pin and a Gnd on the car, and the same directly across the sender (case-to-electrode).
This suggests that the earth return path is GOOD.
The sender (though apparently the correct one for this cluster) does not seem to work.  Gauge doesn't move but will if I earth the sender wire.  However, I am going to cheat and just put the ignition on and pull the sender and heat it up while i earth the case/sheath.  If it then works it suggests that there is no thermostat and the oversized radiator is keeping the coolant below the operating range of the sender.
Update:
OK, I pulled the GTR101 sender out of the block and put a bung in it.
Earthed the case of the sender and stuck the sender in a cup of recently boiled water.  The gauge came up off the stop (at last) and almost to the "normal" marking.  That is where I would expect it to be hovering around.  Pulled it out the water and shoved the tip of the sender into a turbo-lighter flame for a few seconds.  Gauge moved higher to be just below the "H".
My Conclusion:
There probably isn't a thermostat in the engine and the oversized radiator keeps it so cool that the water never gets hot enough to register on the gauge.
I don't think that is good for the engine, so I will fit a thermostat ASAP.
Thanks all.  :-)
Go to the full post
22 replies to this topic
#1 DClarke1954
DClarke1954
  • 93 posts
  • Local Club: Essex Mini Club
Posted 13 March 2025 - 04:47 PM
1275 engine Classic Mini, probably Stage 1 or better.
I have been trying to find why my temp gauge isn't showing any temperature at all.
Grounding the sensor wire makes the gauge show "H" and then some. ;-)   So gauge and wiring is OK but the sensor isn't  presenting a resistance value the gauge is looking for.
I've tried 2 different senders (maybe a mismatched sender/gauge combo).
But, today when running the engine after refurbishing and refitting the fuel pump I noticed that the radiator and pipework all rose in temperature together at the same time and at the same rate, in fact the top of the radiator felt warmer than the top hose and heater-hoses to the touch.
To me, this rather suggests that someone has omitted to fit a thermostat at all.
I had heard that removing the thermostat was a bad idea because it meant that the coolant flow was not as god & BLMC intended it to be and cylinders 3 & 4 could overheat as all the coolant took the short-cut round 1 & 2.
This may be fact, or just an "old-wives-tale".  Happy to pull the housing to check for a stat, but before I rush into it, is it a big problem or just an urban myth?
Cheers!
Dan.
#2 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 13 March 2025 - 05:14 PM
For use on the road, a thermostat is necessary. Otherwise the engine will be operating outside its nominal temperature most of the time.
#3 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 13 March 2025 - 06:02 PM
Road car - It needs to get to temp quickly for tolerances. Fit a thermostat
#4 Spider
  • 15,106 posts
Posted 13 March 2025 - 06:52 PM
It's important to run a thermostat, as the other guys have said, to get the engine up to temperature for it's correct operation. If you read all tuning manuals, they'll all start off with words along the lines of " get the engine up to operating temperature ".
It's also needed for the Oil, which won't lubricate properly until it's also up to temperature. This will also help no end from removing moisture from the oil that enters the crankcase from the breathers and reduce the formation of acids.
However,,,, given your description here, I think it may have a thermostat fitted.
It's best to first establish if the gauge is in fact working. I think I asked the question in one of your other threads - what brand / type temperature gauge are you running ?
This may be fact, or just an "old-wives-tale".  Happy to pull the housing to check for a stat, but before I rush into it, is it a big problem or just an urban myth?.
Old wives' tale.
#5 Steam
Steam
  • 816 posts
  • Local Club: Victorian Mini Club
Posted 13 March 2025 - 07:30 PM
You are working on 2 different issues, they may be vaguely related but not directly.
To establish what is going on with your temp gauge you should remove the sensor and see what it does when dunked in kettle hot water, mid range on the gauge is the aim here. You could also use a potentiometer or various resistors in place of the sender to work out what your gauge needs resistance wise from the sender. This thread is valuable
https://www.theminif...p-sender-specs/
The thermostat issue may be due to a blanking sleeve being fitted or nothing, you will have to check it. It may be easier to remove the top hose from the housing than battling with the tstat housing as tney can be a real pain to remove and refit sometimes.
#6 DClarke1954
DClarke1954
  • 93 posts
Posted 13 March 2025 - 09:09 PM
That is the $64,000 question, who knows?
The car seems to be a "bitsa" in many regards.  Yes, the gauge is working (as I said above) if I ground the wire the gauge flips to the top of the scale.  If I put a variable potentiometer on there I could mess around with it to find the gauge's top/middle/lower values.   What gauge is it?  No idea, it's the one in the dash cluster, who made it?  No idea, what model is it?  No idea.
I suspect it is a common one for a MK3 mini 1,000 with a binnacle dash that has Speedo, Fuel & Temp Gauges Rev counter (L-R).  Who made it, what is it? ask me another.  LOL
It looks like this one, but not quite as smart/tidy.
I am going to fit an 88° thermostat anyway (because for a road car that's the sensible thing to do), and then address the temp-gauge conundrum later.  Thanks for all the help folks.
Good to hear that cooking cyl's 3&4 if you have no thermostat is an "old-wives-tale".
Thanks for the help.
Edited by DClarke1954, 13 March 2025 - 09:20 PM.
#7 DClarke1954
DClarke1954
  • 93 posts
Posted 13 March 2025 - 09:18 PM
Hi Dave,
So far I have dunked 2 different part number temp sensors in water and brought it to the boil to watch the resistance values change, so I know the sensors work.
As you say, I don't know if the sensors are compatible with the binnacle temp gauge, but I know that the gauge works because if you earth it it goes to "H" and beyond.  :-)
Good call on popping the hose and not the housing, I can stick my pinky in there and feel if there's a thermostat in place or just an empty space.
My fear was (having read a mini spares site that said "you will destroy cyls 3 & 4 if you run W/O a thermostat") that I would damage my engine without one.  But folks are saying that's just bunkum.  :-)
#8 Ethel
  • 26,060 posts
Posted 13 March 2025 - 10:53 PM
It's possible there's a broken thermostat that's not closing properly.
#9 Spider
  • 15,106 posts
Posted 14 March 2025 - 02:51 AM
OK thanks.
That's a factory fitted Smiths unit. A GTR101 Sender should be the correct one, but all I've tried / tested in recent years all make the gauge read hotter than is the case.
If it is all working properly, even without a thermostat, you should see some temperature read n the gauge.
If you have teflon or any other sealing tape on the sender, take it off. These don't seal on the thread, but on the tapered seat. Any tape you put on has a good chance of insulating the body of the sender from earth, rendering it useless. Before you disturb the sender, disconnect the wire from it, and measure the resistance from the terminal sender to an earth (not the body of the sender to start with), with the engine cold, you should be reading something around 350 - 400 ohms.
#10 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 14 March 2025 - 03:02 AM
Is it wired in using the gauge voltage stabiliser?
#11 68+86auto
68+86auto
  • 1,005 posts
  • Local Club: Queensland Mini Car Club
Posted 14 March 2025 - 03:12 AM
Unless the PCB has been modified, it has to have the stabiliser fitted to work. Always good to make sure someone hasn't modified it though.
#12 DClarke1954
DClarke1954
  • 93 posts
Posted 14 March 2025 - 09:49 AM
If the voltage stabiliser is a common element to all gauges and required for them to work then as the fuel gauge works properly I would say "Yes".  :)
#13 DClarke1954
DClarke1954
  • 93 posts
Posted 14 March 2025 - 09:54 AM
OK thanks.
I understand its a 1-wire sender and uses the body as the return path, sealant on the threads should NOT be the issue if the sender does indeed mate with the matching conical surface in the casting.
The conical surface should be all that is required for both sealing and earth-return path AFAIK, is that not so?  So the presence of sealant tape should not matter.  But I have a GTR101 arriving today so I will swap it out pronto.
Thanks for the help, I am getting there slowly.  :)
#14 Spider
  • 15,106 posts
Posted 14 March 2025 - 10:24 AM
Tape or other sealants aren't needed or desired on the Sender, especially in light of the issues you are having.
<EDIT: Smiths also specifically state not to use tape or sealant;-
https://www.smiths-i...tal-diagram.pdf
Edited by Spider, 14 March 2025 - 10:30 AM.
#15 NLinPEN
NLinPEN
  • 101 posts
Posted 14 March 2025 - 11:57 AM
OK thanks.
