Dont Understand The Timing Setting In Haynes Manuel
Best Answer alpder , 10 March 2025 - 02:23 PM
It means "8 degrees is the ideal setting, but anywhere between 6 and 8 is acceptable."
Suck-eggs advice: a dob of something white on the pointer and rubbed into the 8-degree mark make the job much easier.
Go to the full post
4 replies to this topic
#1 Abbot
Abbot
  • 105 posts
Posted 10 March 2025 - 01:03 PM
I just got my Mini running after a rebuild and a long time doing nothing.
I want to set the timing more precisely now with my Timing Gun
My Mini is a 998 standard year 1989
the Ignition Timing in the Haynes Manual page 5B 2  says
Mini saloon and variants, 998 cc 1982-on
 1989-on low compression                           8deg  +0deg  -2deg BTDC at 1500rpm
What does that mean?
All other sections give just 1 value which is what I was looking for
Edited by Abbot, 10 March 2025 - 01:03 PM.
#2 sonscar
sonscar
  • 2,982 posts
Posted 10 March 2025 - 01:19 PM
Roughly between 6 and 8 degrees before tdc.8+0=8 and 8-2=6.Steve..
#3 alpder
alpder
  • 377 posts
  • Local Club: MCR
Posted 10 March 2025 - 02:23 PM   Best Answer
#4 68+86auto
68+86auto
  • 875 posts
  • Local Club: Queensland Mini Car Club
Posted 11 March 2025 - 12:05 AM
It also says that it should be done at 1500RPM  with the vacuum advance hose disconnected.
#5 gazza82
gazza82
  • 3,004 posts
  • Local Club: TMF+
Posted 11 March 2025 - 07:25 PM
And the hose plugged to prevent the air upsetting the idle ..
