Choice Of 2" Exhaust
17 replies to this topic
#1 Java_Green
Java_Green
  • 170 posts
Posted 08 March 2025 - 06:51 PM
According to diverce sources the recommendations is to go for an 2" exhaust when power exceed 100bhp. Any recommendations considering manifold as well on 2 box system with side exit? Preferably with the slide on fixations. Any good stainless steel options for the system?
#2 nicklouse
  • 18,538 posts
Posted 08 March 2025 - 07:48 PM
Nah, what power exactly?
would not, did not go that big for 124.
but application and build will determine what size you need.
#3 Java_Green
Java_Green
  • 170 posts
Posted 08 March 2025 - 09:24 PM
7-port, supercharged (~9-10psi), fuel injection (port injected), rev limit at 6500rom. Not sure how much power/torque I will get.
What I do not want is things going hotter than needed due to too much back pressure.
#4 absx2
absx2
  • 905 posts
Posted 09 March 2025 - 08:17 AM
I did wonder why a 2" exhaust and now I know :)
I don`t think you can go wrong with a Maniflow system, you can talk to them and they can get you what you need.
https://www.maniflow...ry&category=201
Edited by absx2, 09 March 2025 - 08:25 AM.
#5 Steve220
Steve220
  • 5,038 posts
  • Local Club: BMC
Posted 09 March 2025 - 09:21 AM
If you can get hold of one, playmini used to make a 2" stainless system, but stopped producing them a few years ago. They often turn up second hand.
#6 IronmanG
IronmanG
  • 1,225 posts
  • Local Club: Box hill. Lsmoc member
Posted 09 March 2025 - 12:51 PM
Bagsport do exhaust with your choice of size number of boxes etc
#7 Java_Green
Java_Green
  • 170 posts
Posted 30 March 2025 - 06:59 PM
Are the inlet ports in a 2" manifold (e.g. C-AHT289) larger than standard?
#8 imack
imack
  • 2,096 posts
Posted 30 March 2025 - 07:16 PM
They are on my Maniflow large bore long
3 into 1 manifold.
Large bore competition gasket perfectly matches the exhaust ports in the head and in the manifold. Gasket shown on standard head for comparison, plus modified head vs standard.
#9 nicklouse
  • 18,538 posts
Posted 30 March 2025 - 07:35 PM
Sorry no such thing. The 2” is the exhaust.
the manifolds that fit a 2” exhaust can be various diameters but in all cases the center one is larger.
#10 Java_Green
Java_Green
  • 170 posts
Posted 30 March 2025 - 08:05 PM
Hmm...
If it is just the exit of the manifold that is matching a 2" system, changing the Y-piece should be enough. Am I right?
#11 timmy850
timmy850
  • 3,305 posts
  • Local Club: MITG
Posted 01 April 2025 - 06:07 AM
It’s clear from the pictures from imack that his manifold is definitely bigger at the ports too. I would assume it’s bigger from the ports all the way to the collector
I think Nick has read that wrong and thought you’d meant 2” from the head
#12 Java_Green
Java_Green
  • 170 posts
Posted 01 April 2025 - 09:26 AM
3 into 1 manifold.
I would very much appreciate if you could measure the exhaust port sizes of what is named as "large bore".
#13 imack
imack
  • 2,096 posts
Posted 01 April 2025 - 03:44 PM
Engine is currently fully built and in the car, so not possible to measure. It's the competition gasket from MED. They only list one exhaust port dimension, I don't know whether it's an outer or centre port.
#14 imack
imack
  • 2,096 posts
Posted 01 April 2025 - 04:25 PM
The pictures I posted were taken a few years ago. I'm certain that I actually had to enlarge the exhaust ports on that gasket using a dremel, to match the ports in the head and in the manifold.
#15 imack
imack
  • 2,096 posts
Posted 01 April 2025 - 04:30 PM
Double post
Edited by imack, 01 April 2025 - 04:30 PM.
