Connections To A Hs4 Carb.
Best Answer Abbot , 08 March 2025 - 04:17 PM
:shy: Problem solved I think.  What I was struggling with was the route and where to connect what i now know is the crankcase breather connection to the carb.
I was making life hard for myself as I had removed the tappet gallery cover plate so i could get access to the low down fuel feed pipe.  The connection I could not find was on the cover sitting on my tool box.
Go to the full post
4 replies to this topic
#1 Abbot
Abbot
  • 105 posts
Posted 08 March 2025 - 01:11 PM
I am now getting close to finishing my rebuild of LHD 998 Mini 1989.
There is a large diameter pipe (not fuel) connected to a tube at the base of the dash pot housing.
I cannot work out where the other end should be connected to.
Thanks for any help
#2 nicklouse
  • 18,524 posts
Posted 08 March 2025 - 02:53 PM
Depends which one it is. Most likely the breather system connection.
have a read
https://sucarb.co.uk...e-carburetters/
#3 Abbot
Abbot
  • 105 posts
Posted 08 March 2025 - 03:55 PM
Thanks for the link.  Not sure it answers my question which is more to do with the Mini end of the connections
#4 Abbot
Abbot
  • 105 posts
Posted 08 March 2025 - 04:17 PM   Best Answer
#5 Spider
  • 14,785 posts
Posted 13 March 2025 - 03:47 AM
While this shows 'the full monty' it's pipe 7you're interested in
