1969 Mk2 +Earth .. Dynamo Change
Best Answer alpder , 06 March 2025 - 08:41 PM
There are probably +ve earth dynamator style alternators available?
Do choose a quality make: My 'Tudor' brand Dynamator failed badly because of a terrible piece of design inside it: https://www.theminif...ears/?p=3771972
But the badly designed part which caused the fault could be removed, so long as you don't need the PTO on the back of it. The rest of the alternator looked reasonably well made.
Go to the full post
5 replies to this topic
#1 DavidHopkins
DavidHopkins
  • 19 posts
Posted 06 March 2025 - 06:52 PM
Evening all, I was wondering people’s views on a change from the standard dynamo to a Dynamator? My Mk2 1969 1000 is on a dynamo and I’d like to change it to an alternator but as everything on the car is positive Earth it’s not a simple change. The Dynamator seems to be perfect for the change but does anyone have any experiences of these units? Thanks in advance!
#2 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 06 March 2025 - 07:44 PM
Switching a dynamo to negative earth is pretty straightforward and a popular modification to do. Have you got any non-factory electrical components that are specifically positive earth?
https://mossmotorshe...negative-ground
#3 DavidHopkins
DavidHopkins
  • 19 posts
Posted 06 March 2025 - 08:25 PM
Evening, yes the ignition is electronic and positive Earth, the rev counter too, the other smiths gauges can, I assume, be rectified by changing the voltage regulator to a negative one.
Edited by DavidHopkins, 06 March 2025 - 08:31 PM.
#4 alpder
alpder
  • 377 posts
  • Local Club: MCR
Posted 06 March 2025 - 08:41 PM   Best Answer
#5 MatthewsDad
MatthewsDad
  • 805 posts
Posted 07 March 2025 - 01:03 PM
I asked the same question a while ago. This is the advice I received.
https://www.theminif...s/?fromsearch=1
#6 alpder
alpder
  • 377 posts
  • Local Club: MCR
Posted 08 March 2025 - 11:48 AM
My '64 will be keeping its dynamo. Like the idea of an electronic regulator hidden inside the control box, though.
