Flatting Down An Idler Gear Thrust Washer?
3 replies to this topic
#1 babsbrown
babsbrown
  • 406 posts
Posted Today, 11:08 AM
Good morning guys,
My idler gear clearance is currently 3.5thou
I want to get it to 4 minimum.
I know they sell the different size thrusts. But for the sake of 0.5 thou, could I rub it down?
I have a thrust washer that is only 5 thou too big, but that would get me to 4 thou clearance.
I'm thinking a glass plane with wet and dry taped to it flat.
I know you can give the primary gear washers a tickle with emmery paper. I'm hoping I can do the same here.
Edited by babsbrown, Today, 12:11 PM.
#2 nicklouse
  • 18,456 posts
Posted Today, 11:17 AM
The issue you have is compared to the primary gear washer it is much harder. I would look to get it ground.
but what about looking at other gaskets?
Edited by nicklouse, Today, 12:27 PM.
#3 Midas Mk1
Midas Mk1
  • 5,765 posts
  • Local Club: S.U.N.M.C
Posted Today, 11:28 AM
Easiest way get a selection of gaskets, use a micrometer and write down the various thicknesses - penny to a pound they all vary.
#4 babsbrown
babsbrown
  • 406 posts
Posted Today, 12:35 PM
Thanks guys I remembered I had a different idler gear. Still A+ that took up the tolerance just fine to a perfect 4 thou.
Please could an admin delete this post. I don't want to clog up the forum with simple questions.
